4.0 Pushrod vs. SOHC | Ford Explorer - Ford Ranger Forums - Serious Explorations
IronIndian
Glendale, CA
1991 Mazda Navajo
Could someone elaborate on the differences between the pushrod 4.0 and the SOHC 4.0? My Pushrod 4.0 took a dump and am looking for options on a replacement...Could I use a SOHC engine? What would you guys replace it with? My budget is around $1k...I'd like to hear from yall!!! :D Thanks...
Join the Elite Explorers $20 each year.
Elite Explorer members see no advertisements, no banner ads, no double underlined links.
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
B2 "Slightly" Modified
Callsign
FOURTEN
NO you cannot just bolt in a SOHC in the OHV's place. there are many differences, also the SOHC never came in a 91 which has a completely different front suspension = does not exactly fit.
Yes it is possible to do a SOCH drivetrain conversion, but not for $1000.
It would be as much work as a 5.0L V8 conversion many say.
Your best bet is to have your OHV rebuilt or replaced with a low mile unit.
What happened to your engine?
IronIndian
Glendale, CA
1991 Mazda Navajo
Blown headgasket :(
LBarr2002
Leesville, SC
'91 XLT 4x4, '92 XLT 4x4
So did it hurt something else? Why can't you change the gasket? It'll only cost the $100-$150 for gasket set and some time.
IronIndian
Glendale, CA
1991 Mazda Navajo
It already has 100k+ miles on it...Mind as well pull and replace...
Hartman
Indianapolis, IN
You're going to be hard pressed to do any type of engine swap for a grand. Even getting a new OHV in there will be tough with that budget.
410Fortune
Truck Season!!
Staff member
Moderator
NORTH IDAHO, 7B
Callsign
FOURTEN
BUT getting two heads from a 93-94 4.0L and having them rebuilt, then bolting them on is very do-able for that budget. The 93 heads were updated and stronger.
the short block is likely fine. You can do a compression test to make sure.
Teh OHV 4.0L in those 91's, if you can keep them cool and avoid head issues, they will run forever. 100K + is half life easy.
Rhett
Let Them Eat Cake
Cape Girardeau, MO
94 Sport 4x4
It sounds like, from what you posted, that you did not crack the head! Or maybe you do not know yet. Anyway, why not tear it down, have it tested as was said, and at best, simply re-do the gasket, and at worst, find some new heads and put them on. Either way you'll be in your budget I think.
LBarr2002
Leesville, SC
Like 410 said, 100K miles is low milage for these things. Fix it as cheap and easy as possible IMO.
