4.0 SOHC Fuel System 'Hack'
JonC
Derby
'99 UK spec - LPG soon!
Hi guys,
had a bit of a result this week which I thought worth sharing with the wider community. The background to this is that my 1999 UK-spec 4.0L Explorer 'gently expired' recently whilst driving in that it just stopped. Something told me it was the fuel pump but at the roadside, I couldn't prove it.
I'd had the presence of mind to buy a recovery package some time ago so I had the truck recovered to home but on a large, ramp truck, it could only be unloaded onto the road outside my house and not up the drive where I can work on it more comfortably.
So what do you do? There's only me and the ladies and 2 1/4 tons of dead truck - not something you want to push and even if you did, you're not going to push it up the ramps for getting underneath!
I did the required electrical inspections and convinced myself it was a dead pump so one last check, I took the Schrader valve out of the left-bank fuel rail and using a funnel and hose, poured some fuel in. It tried to fire and run so at that point, I'm more convinced about the pump but as injectors have no suction, gravity isn't going to get me enough fuel in there to drive it.
Enter the hand-held garden spray...
Ditch the nozzle and adapt a hose onto the fuel rail valve, pump up the gas and sure enough, we have enough fuel - under enough pressure - to drive the truck across the road, up my drive and onto the ramps where I have subsequently successfully replaced the duff pump.
So now you know!
Pictures
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
dezufo
1998 ford explorer/LPG
Very interesting work around which I shall probably end up doing to mine as it will turn over but not fire up. Can you tell me where your fuel pump relay is situated as layout of relays in the main box on my '98 are not the same as in my owners manual + haynes manual
JonC
Derby
No problem - just uploaded a drawing under the same link as the photo. Strangely enough, I had exactly the same issue - don't think I've found anything in the Haynes manual that actually relates to my truck!
When you compare the fuse box drawing with your truck, it will be 'upside down' i.e. the big fuses will be nearest the windscreen. The FP relay is the 30/40A device 'on it's own' as you'll see.
I did various electrical and continuity checks, proving power at the relay terminals, pulling the relay then plugging it in with the ignition on (you should feel the relay switch over) and testing between the relay socket and inertia switch. They didn't check out exactly as I expected but then as we now know, you can't trust the Haynes manual wiring either!
In the end, I jumped 12V onto the outgoing side of the inertia switch and still got nothing from the pump. Beyond that, there's only the connector under the vehicle and compared to the pump itself, that's got very little probability of failure so at that point, I committed to a new pump. I suspect the old one died from being 20 years old, not from the 50,000 miles which is all it's done!
If you haven't already dropped your tank - DON'T - until you watch this video:
This guy will stop you breaking things (I've seen others that don't!) - notably the evap. hose which is as stiff as a board and will break it's connection if you go too far.
Good luck - and if there's anything I might be able to help further with, give me a shout!
dezufo
can you tell me which colour wire you connected to on the inertia switch so I can check if pump runs or not
this is my main box and the relay on its own does the blower motor.
the one directly below is engine management, the one to the right of that is the starter
the small relay on its own is wipers hi/low
the one below that is the horn, the one to the right of that is any body's guess but I think it may be wiper delay unable to confirm because the switch has stopped working
JonC
Derby
That's strange - because that's exactly the arrangement in my fuse box. Mine is a 99-registered, 98 model. You can check the relay manually - if you pull it out, then turn on the ignition, when you put the relay back, you'll feel it switching (they go with a good clunk). I checked the continuity on mine and the 30/40A relay just below the small fuses definitely powers the fuel pump.
There's a green/yellow wire on the IFS and that's the supply from the relay. The pink/black at the IFS is the outgoing to the pump. Jump 12V +ve directly onto that and if the pump is good, it'll run.
You're right about all the small relays by the way.
Just as an aside, have you checked for pressure on the LH bank fuel rail? There's a Schrader valve just behinds the EGR valve. Give that a prod and if there's pressure, it'll either hiss or leak a little fuel. If your pump isn't delivering, there will be nothing there to speak of.
dezufo
I found out mine by turning the ignition on and removing the relays one by one, Thanks for the info will try a jump lead on the IFS at the weekend if weather is nice also the valve
JonC
Derby
Just out of curiosity, what LPG system do you have? I was surprised to find that some can be made to start on LPG - if you have the 'technique' for your particular system!
dezufo
Its a stag 300 ecu and I lost the instructions for getting it to start on lpg but I could warm up the heat exchange valve to about 40'C so that the liquid turns to gas and then start it but I'm reluctant to go that route just incase it goes BANG!
JonC
Derby
The temperature is academic (in the UK) as Propane boils at around -42C.
The liquid constantly turns to gas as in the tank - that's why you can never completely fill an LPG tank - the space above the liquid accommodates the evolved gas. As I remember, the issue is in 'fooling' the system into opening the solenoid at the 'wrong' time. My previous Explorer had a Leonardo system and there was a specific sequence which you could apply to the changeover switch which would then make the system open the solenoids and let it start immediately on LPG.
Might be worth looking up. I'd be more cautious if it's single-point injection though.Problems only arise when it doesn't start. That's when you get a build up of gas in the manifold and if you ignite that, you're then shopping for a new manifold (after you change your pants!).
D 98 sohc will not start UK Explorer Owners Forum 11
W Rover part numbers v6 4.0 SOHC UK Explorer Owners Forum 8
U engine timing tools needed 4.0 SOHC UK Explorer Owners Forum 11
A Please Help, New User 4.0 SOHC stuttering problem - Totally stuck! UK Explorer Owners Forum 10
F Gasket set 4.0 SOHC UK Explorer Owners Forum 1
N bought a 97 explorer 4ltr SOHC v6- help UK Explorer Owners Forum 5
E Advice needed on removing serpentine belt, serpentine belt tensioner- '99 4.0l SOHC UK Explorer Owners Forum 2
Howard New Plugs SOHC UK Explorer Owners Forum 22
D timing chain's 4.0 sohc UK Explorer Owners Forum 33
S Uk Engine, OHV or SOHC? UK Explorer Owners Forum 1
P Fuel consumption UK Explorer Owners Forum 5
B Fuel pump UK Explorer Owners Forum 1
R Fuel filler neck UK Explorer Owners Forum 8
K Fuel pump access hole UK Explorer Owners Forum 3
K Temperature guage and fuel economy UK Explorer Owners Forum 7
M Fuel filler neck UK Explorer Owners Forum 11
I Expiring Soon: Shell Fuel Promo & Sky Sports Day Pass UK Explorer Owners Forum 0
S Fuel Filler Pipe UK Explorer Owners Forum 18
B Wanted Fuel filler neck section with pipes UK Explorer Owners Forum 2
S Locking fuel cap UK Explorer Owners Forum 4
S Fuel lines UK Explorer Owners Forum 2
O HHO kit save fuel?? UK Explorer Owners Forum 6
H Fuel Filler Cap UK Explorer Owners Forum 3
A Fuel cost e-petition UK Explorer Owners Forum 4
D Fuel Starvation UK Explorer Owners Forum 13
I Fuel leak! UK Explorer Owners Forum 3
K Fuel computer UK Explorer Owners Forum 7
K Fuel Filter UK Explorer Owners Forum 5
blueka locking fuel caps UK Explorer Owners Forum 2
SB98UKexplorer For Sale NEW heater resistor & fuel locking cap with keys UK Explorer Owners Forum 7
B Fuel Filter Change Without The Quick Release Tools... UK Explorer Owners Forum 2
SB98UKexplorer DTM fuel / ratio guage, who has one? UK Explorer Owners Forum 2
S Fuel problems. UK Explorer Owners Forum 6
G Making a fuel filter removal tool UK Explorer Owners Forum 2
G Explorer fuel pressure UK Explorer Owners Forum 7
J fuel filter tool? UK Explorer Owners Forum 7
B Code Reader With Live Fuel Trim Data! UK Explorer Owners Forum 20
chrisquelch reset fuel light UK Explorer Owners Forum 2
J question on fuel pressure regulator UK Explorer Owners Forum 20
SB98UKexplorer done a fuel pressure test and whats the factory psi? UK Explorer Owners Forum 0
J Fuel tank sender problem? UK Explorer Owners Forum 5
rich uk Help need fuel pipe tool UK Explorer Owners Forum 8
S Fuel Economy since 00m12 fitted UK Explorer Owners Forum 4
kernowman Fuel Pump Connector UK Explorer Owners Forum 6
kernowman Fuel pump died UK Explorer Owners Forum 8
S fuel reserve question UK Explorer Owners Forum 2
D OBD2 Which One can read fuel trims?????? UK Explorer Owners Forum 5
rich uk uk fuel cap part no UK Explorer Owners Forum 2
blueka Fuel Consumption (again) UK Explorer Owners Forum 1
F fuel savers UK Explorer Owners Forum 4
Similar threads
