JackOfAllTrades77
- April 25, 2021
- JASPER, TN
- 2005 Ford Ranger XLT 4x4
2005 Ford Ranger XLT 4x4 with the 4.0 SOHC engine.
Had a timing chain guide fail so I took my truck to a family friend to have all of the chains and guides replaced. He has the chains, sprockets, and guides replaced but has had an accident before he could finish. The truck is now in my garage and I need to finish it. The last time I spoke with him, he said it needed to be timed correctly and everything put back together. I've done older model Fords, Chevys, and Dodges, but nothing like this.
I've read several posts on here and I've been able to get my hands on a timing tool kit. The crank has the keyway at 12 o'clock. If I put the crank holder on the damper and slide it onto the crank, it goes on as I've seen on other posts with the tailpiece fitting under the block. Does this mean, without a doubt, that the #1 piston is at TDC?
If at TDC, I'm looking at the camshafts and neither is correct based on what I've read so far. The slot on the driver's side cam is almost straight up and down and the slot on the passenger side is diagonal but does not line up with the head. How do I use the timing kit to put the cams back in time? Heck, how do I turn the cams to make them fit the timing tool guide?
I apologize for the long post, but I'm lost on this engine and I need to get it back together quickly.
