Eric1971
- May 1, 2019
- 1995 Explorer Eddie Bauer
While changing the oil I was reminded that I have a very slow, minor oil leak from somewhere above the area of the oil filter. I only ever see it when I'm down there by the drain plug and filter. I've checked as much as I can and it does not seem to be the filter, filter adapter, drain plug, or oil pan/gasket. It looks like it's farther up than all those. I checked as best I could and don't see any leaks up top from the valve covers, or anything else I can see from the top, looking thoroughly with a light.
I'm betting one of you knows immediately where it probably is, or at least a few ideas where else to look.
Thanks!
Thanks!
