For Sale - 4.0L Primary Timing chain update kit | Ford Explorer - Ford Ranger Forums - Serious Explorations
For Sale 4.0L Primary Timing chain update kit
These sell for around $180 from your local Ford dealer. Will sell for $85 shipped. See pics below, box just opened to take pictures and make sure Ford packed all the parts.
Here is a copy of the TSB. This is for balance shaft engines only. The applications are listed below in RED...
TSB 04-15-4
08/09/04
RATTLE NOISE FROM PRIMARY CHAIN DRIVE AREA
2000-3000 RPM - 4.0L SOHC ENGINE
FORD:
1999-2002 Explorer
2001-2002 Explorer Sport Trac,
Explorer Sport, Ranger
MERCURY:
1999-2002 Mountaineer
This article supersedes TSB 02-08-01 to update part numbers and add a labor operation for vehicles with auxiliary air conditioning.
ISSUE
Some vehicles equipped with the 4.0 SOHC (single over-head cam) engine may exhibit a primary timing chain rattle noise. The noise is heard during hot and cold engine operation (but mainly heard on cold engines) under acceleration, typically at 2400-2500 RPM. To verify concern, accelerate in 2nd gear between 2000 and 3000 RPM and listen for rattle noise that sounds similar to spark knock. This may be caused by the primary timing chain tensioner system.
ACTION
Replace the Primary Timing Chain Tensioner, Chain Guide, Jackshaft and Crankshaft Sprockets with a Primary Timing Chain Tensioner Kit. The Kit includes an improved Primary Chain Tensioner, as well as updated Primary Chain Guide, Primary Jackshaft, and Crankshaft Sprockets. Required fasteners, Primary Timing Chain, and Front Cover Gaskets are also included. Refer to the following Service Procedure for details.
SERVICE PROCEDURE
Verify the condition. Obtain the correct Primary Timing Chain Tensioner Kit and follow the instruction sheet supplied with the Kit.
Use Kit 2U3Z-6D256-CA (balance shaft engines)
for:
^ 1999-2001 4X4 Explorer/Mountaineer
^ 2001-2002 4X4 Sport/Sport Trac
^ ALL 2002 Explorer/Mountaineer, except engine codes 2G-960-AA and 2G-964-AA.
Use Kit P/N 2U3Z-6D256-DA (non balance shaft engines) for:
^ 1999-2001 4X2 Explorer/Mountaineer
^ 2001-2002 4X2 Sport/Sport Trac
^ 2002 MY Explorer/Mountaineer with engine codes 2G-960-AA and 2G-964-AA
^ ALL 2001-2002 Ranger
Anime
EF YEAH!!
2018 EX Sport Concept
Noslo351
Hebron Ct
2002 Explorer Limited V8
I tried to delete the other one but couln't see how to do it. I just wanted to change the Ad a bit to make it more clear. Sorry.
Anime
EF YEAH!!
You can change your ad, and other posts, by using the "edit" button on the lower right corner of your posts.
schwenk
Richmond, VA
1999 XLT
i want it!
pm sent!
Noslo351
Hebron Ct
Sale pending payment....
Noslo351
Hebron Ct
