ahuggins6
- May 20, 2011
- New Boston, TX
- 1999 explorer 4.0 auto
So I replaced my chains and tensioners a few weeks back. 2nd engine I've done this on over the years. Swore the first time I'd never do it again. Sold the first one. Was given a 99 in great condition. I started driving it at about 150k, now its at 215k.
It's got a slight vibration/rough idle now since the engine went back together. Also, fuel mileage dropped shortly before the tensioners finally let go, and it hasn't recovered as I expect it would. It runs great, even at idle, but it's got that vibration at idle that gets old sitting at red lights and drive thru windows and such.
I didn't have instructions and I was in a hurry when setting the timing. The only thing I can think of is that I was supposed to rotate the engine 360 before tighting the second cam. I'm thinking that the cams are timed such that two cylinders are on the same stroke at any given time. This would make the MAF read really big air flow at one time and nearly zero the next--if the air flow can even vary that much..??
Another possibility is that my tool kit is just a cheap piece of junk that doesn't work perfectly. It's the diamond power setup. I was going to pick up the OTC tool like i'd used before, but at the time the tensioners came apart, I was too broke to get a good setup. Anyway, this crank pulley holder tool is built so that it wiggles around on the pulley and doesn't seat well. I think it's still pretty accurate in where it locates the crank relative to the spot it hits on the block. This is why I think it's a matter of turning the engine one rev before going to the second cam.
I installed new platinum plugs before putting the engine back in the vehicle, so I guess I could have one that's cracked or something?
What do you folks think?
