  • We are aware of the issue with our internal search engine and we will be bringing it back online shortly. For now please use the Google search bar near the top of each page. Thanks, Rick
4.6 four valve swap ?
scruff
Atlanta, GA
2000 Limited chassis only
Anyone ever done, or researched swapping a Lincoln Mark viii 4 valver into a Gen 2 in place of the 5.0 ?
They run pretty much the same trans, so that should be fine, but I am guessing the width might be tough.
They look like an old school hemi with these valve covers.
http://www.sullivanperformance.com/index.htm
They're a pretty trick thing considering how cheap they are, 280hp rated 310 or more with exhaust and Cobra intake 6 bolt mains with an iron crank and the bare block only weighs 86 pounds !
Just curious.
MountaineerGreen
Towing Moderator
Moderator Emeritus
North East Arkansas
2012 F150 4x4
Its been discussed before, but in the smallish body of the 2nd gen wont accommodate the motor and keep creature comforts like heat and air. There was a guy who did it in a 2wd Ranger, but it has different crossmember allowing for the oil pan. I believe custom headers have to be fabbed up to clear the steering and other stuff. Ill see if I can find the thread- they have the obligatory picture of the two motors side by side.
J valve opinions Need for Speed! 28
K Rebuilt 5.0 valve train noise Need for Speed! 11
RubySlow Coates Rotary Valve anyone know about this? Need for Speed! 9
section525 NOTE: Aluminum tall valve covers do not work... Need for Speed! 6
R Has anyone found a 75 mm TB with the IAC valve port? Need for Speed! 1
S 00 SOHC tappet/valve noise? Need for Speed! 5
B M90 rotor case swap Need for Speed! 18
O 2000 explorer v6 to 302 swap? Need for Speed! 0
T Boost Intentions Lightning swap! Need for Speed! 11
99SportX '99 Explorer LS Swap Finished - Was has anyone done it? Need for Speed! 59
J Explorer Sport 5.0L Swap Need for Speed! 9
C 2003 ford explorer sport trac 2wd 4.0 v6 to v8 swap??? Need for Speed! 8
B 01 explorer sport LS swap Need for Speed! 14
H 5.0 swap manual trans q's Need for Speed! 6
C 351 w swap Need for Speed! 12
P lets have a serious discussion about a 351w swap in a 2nd gen Need for Speed! 24
minelson17 ? for those that have done the 5.0 swap Need for Speed! 19
O Info on V-6 to V-8 swap Need for Speed! 2
F 5.8 swap Need for Speed! 23
E 5.0 swap into my 95 xlt Need for Speed! 3
L 03 x sport engine swap what options do I have?? Need for Speed! 5
J V8 Swap for 96 X sport? Need for Speed! 4
S can i swap my intake with a mustain intake Need for Speed! 4
J SVT/Cobra engine swap advice needed. Need for Speed! 17
A Any Advice on a Ford Ranger engine swap?? Need for Speed! 9
T Upcoming rebuild/swap questions Need for Speed! 0
seth247 Matt's '92/'99 4X4 V8/4R70W swap! Need for Speed! 1059
P 5.0 Swap research... where to start? Need for Speed! 5
D 5.0 swap Need for Speed! 10
seth247 5.0 swap with an electric fan? Need for Speed! 15
seth247 302 swap manual? Need for Speed! 11
S 2002 3.73 to 4.10 swap Need for Speed! 6
I 4.0 OHV to 347 swap Need for Speed! 27
Turdle Wiring diagram explorer/ Mustang TPS Swap Need for Speed! 0
S SWAP: 2001 Explorer 5.0L, and T-56 into First Gen Need for Speed! 6
Turdle Jah's 5R55s Swap for SOHC Need for Speed! 0
T Ooops! I goofed with the 351W swap! Need for Speed! 11
B Cam Swap, Exhaust headers, and S.C? Need for Speed! 18
B 302/ZF5/BW1356 Swap in a 93 Need for Speed! 8
M 5.0 swap Need for Speed! 10
E nitrous cam, and in-car cam swap info thread Need for Speed! 15
E chevy 350 derivative swap? Need for Speed! 9
P 347 swap on 96? Need for Speed! 33
Similar threads
