superboat
- September 14, 2010
- longisland newyork
- 1997 AWD mountaineer
Hey whats going on guys,I kinda ran into a bad situation.I own a 06 mountaineer with the 4.6l v8. Its my daily driver to get back and forth to work. As of most of you already know that changing the spark plugs are a hassle. Well last night cly 8 started misfiring on me.
I pulled the coil out and noticed that there was water inside of the hole which was causing the plug to miss on me.I blew out all the water and any dirt laying down there put some dielectric grease on the coil boot and mounted everything back. Still had a misfire.
So I decided to change out that plug and a 9/16 deep socket that I grounded down so it would fit between the plug and the wall. So I decided to give it a turn and my bad self stripped the plug
. The threads are still fine since the plug never turned but the spark plug its self is stripped.
Any advice or any help would work. I cant find anything on the computer about this problem but I am sure im not the first to run into it. I really don't want to pull the head off to fix a little spark plug. Thanks guys
things i already tried:
6point 9/16 deep---socket slips off
6point 14mill deep---socket slips off
heated up the engine and froze the 14mil socket in the freezer hoping that the cold socket might shock the plug and being that its hot might come out,nopeee---socket slips off
please guys help
please guys help
