#4 cylinder misfire
iamdolfan1
WHITEHALL , PA
91 XLT,93 SPT,99 XLT
My 1999 (4.0) explorer started missing and the check engine light came on . Hooked it up and code read #4 cylinder misfire. Changed plugs (autolite) ran great. Same thing happened again about 1300 miles later this time i replaced the coil (accel), sparkplug wires(taylor), and plugs(accel). Ran great again. Then about 1500 miles later same thing again.I pulled the #4 cylinder plug and it looks fine and i replace it with a new one it runs great again. Any idea what can be causing the #4 cylinder to miss fire?
Join the Elite Explorers for $20. Gets rid of the ads!
Ray-Ray
florida
1999 Explorer Sport
I have a 1999 4.0 ohv. What I have found was the porcelain around the electrode had a very fine crack......for some reason this has only happened with iridium plugs. Good Luck
ranger7ltr
Great State of Texas
1999 Sport
Does the engine feel like it is down on power and actually missing?
In a lot of cases, the fuel pressure and/or volume is not sufficient to sustain the needs of the engine especially under load...You might not even notice it dropping off power-wise when the pressure drops due to a clogged/dirty fuel filter or dying fuel pump...
I ran into this very issue when my fuel tank was extremely dirty and rusty...Even with a new fuel pump and having a radiator shop clean out the tank, the rust came back and would mix with the sloshing fuel and the result was a coffee-colored fuel supply into the fuel filter which would eventually clog the filter and cause starvation...
Your fuel systems pressure should be 65+/- 8 psi and it should not vary throughout the rpm range...If the pressure drops as the load/rpm increases, the fuel pump is losing its ability to supply enough fuel under that loading...
bluestream1
Waterloo Ontario
2000 XLT 4.0 SOHC 4X4
Did you check the plug wires?
rookieshooter
Moderator Emeritus
Martinsburg WV
84 BII "Li'l Samson"
I don't understand how the plug looks good if it is in fact misfiring. Seems it would be sooty, oily or drenched in gas.
bluestream1
Waterloo Ontario
If the injector is bad, and not working right, your plug may still look fine
D 98 Explorer Cylinder #3 Misfire Under the Hood 19
T 4.6l '07 sport trac misfire #3 cylinder Under the Hood 2
F SOHC V6 cylinder 1 misfire Under the Hood 17
9 4.0L SOHC misfire cylinder 1 and rough idle Under the Hood 1
Willard 2004 Ranger Cylinder 4 misfire Under the Hood 25
Brandon96 Sometype of misfire/cylinder fail? help please Under the Hood 4
B Cylinder Misfire 0301 and sometimes 0300 Under the Hood 0
R Cylinder #7 misfire when HOT??? Under the Hood 2
M #3 cylinder misfire Under the Hood 6
jwrezz #3 cylinder misfire Under the Hood 8
J Code 305 - #5 cylinder misfire. Why? Under the Hood 2
M Spongy and Airy Brake Pedal - Brakes Giving Out - Master Cylinder? Under the Hood 10
A Suddenly, oil is fouling cylinder 1 plug - cats too? Under the Hood 5
I Cruise control (NOT Master Cylinder Pressure Switch) Under the Hood 0
T 97 explorer 4.0 ohv cylinder heads Under the Hood 2
T 2007 mountaineer master cylinder replacement Under the Hood 0
H 4,0 OHV cylinder heads Under the Hood 4
J How-to: F250 Booster and Master Cylinder Swap Under the Hood 8
J Brake Master Cylinder Differences Explained (with Pictures and Math!) Under the Hood 27
R Dead miss, single cylinder, P0303. Under the Hood 6
C Please help. #2 cylinder skip I can't chase down Under the Hood 0
P cracked cylinder heads (cologne v6) Under the Hood 3
D ebay replacement cylinder head? (alliedmotorparts2001) Under the Hood 6
B Recommendations for new cylinder heads Under the Hood 2
P Took off Master Cylinder - Reinstall? Under the Hood 1
P What is this part? '01 Explorer Sport Master Cylinder Repair Under the Hood 7
Scott B. Cylinder bore for Rebuild Under the Hood 0
Y prices for cylinder heads Under the Hood 8
T Cracked head over cylinder 4 Under the Hood 5
G 99 4.0 sohc dead cylinder Under the Hood 2
S source for sohc cylinder head Under the Hood 2
M Urgent cylinder head question? Under the Hood 1
9 4.0L OHV Cylinder Heads questions Under the Hood 37
S 2004 Explorer/ #2 cylinder has no compression Under the Hood 3
D Explorer Clutch Master Cylinder Under the Hood 1
Diff Whack Daddy Brake Master Cylinder Port Size?!?!?! Under the Hood 7
K #1 cylinder missfire Under the Hood 7
H Cylinder not firing Under the Hood 4
C Cylinder misfires, pulled codes, need advice. Under the Hood 3
J Do I need to replace the Master Brake Cylinder? Under the Hood 3
D Cylinder Heads Under the Hood 7
M cylinder ident. Under the Hood 6
S Is my master cylinder crapping out? Under the Hood 1
Makahveli Clogged Cylinder Chamber Under the Hood 4
S Random Fouling on Cylinder #4 Under the Hood 8
D Cylinder Head leaks/Coolant Questions - with pictures! Under the Hood 7
M '94 Clutch Master Cylinder Under the Hood 0
N special tools ? cylinder head removal Under the Hood 9
E 8th cylinder is not working Under the Hood 1
B Master Cylinder Woes Under the Hood 4
Similar threads
