4 inch lift help needed.
Frank1669
Oldtown Idaho
1991 Explorer XLT
I wound up with some of a 4 inch lift for my 1991 Explorer, But I need some info from you guys,
The lift is missing the Radius arm drop brackets. I need to know how much they drop them so I can fab up a pair. also anyone know of a vehicle I can get the correct length shocks and brake lines out of for a 4 inch lift? I prefer to get Parts that I can get at any parts store. Trying to keep it cheap as possible - Until I decide if I am going to SAS it or not. Thanks in advance.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
The RA brackets should drop the same amount as the other parts. What brand is it?
Frank1669
Oldtown Idaho
1991 Explorer XLT
I am not sure by looking at brackets I believe it is a tuff country - It came with front axle I got off Craig's list. Previous owner did not remember who made it.
imsick247
Long Beach, CA
1994 Explorer Sport 4x4
James Duff for the brake lines.
C 2 or 4 inch lift... help me decide please Modified 1991-1994 Explorers 12
1 Is 5 inch lift on 94 explorer enough for 34's? Modified 1991-1994 Explorers 13
B 4 inch lift + soa Modified 1991-1994 Explorers 9
K looking for 4 inch lift leaf springs Modified 1991-1994 Explorers 10
A 2ish inch lift questions. Modified 1991-1994 Explorers 10
Jim wright Want to put 35s underneath my Ford Explorer got 3 inch body lift Modified 1991-1994 Explorers 5
E 2 inch lift questions Modified 1991-1994 Explorers 17
J 1991 exploder 4 inch lift. 4x4 problems Modified 1991-1994 Explorers 7
HSlough 4 inch lift? Modified 1991-1994 Explorers 20
M Rancho 2.5 inch lift install directions Modified 1991-1994 Explorers 11
N 1993 ford explorer 2 inch lift, what backspacing for wheels? Modified 1991-1994 Explorers 20
C i have some ? about steering after a five inch lift. Modified 1991-1994 Explorers 7
9 3 inch suspension lift Modified 1991-1994 Explorers 0
G 2 inch lift and dunes Modified 1991-1994 Explorers 4
A Quick question 4 inch lift Modified 1991-1994 Explorers 16
A 4 inch lift question (s) Modified 1991-1994 Explorers 6
V 1.25 inch shackle lift and 2 inch front spacers Modified 1991-1994 Explorers 4
T 3/4 or 1 inch body lift? Modified 1991-1994 Explorers 8
M 2 inch lift..parts Modified 1991-1994 Explorers 6
J 9 inch lift Modified 1991-1994 Explorers 12
9 6 inch suspension lift advice. Modified 1991-1994 Explorers 3
9 i got a 6 inch fabtech lift tell me if got everything Modified 1991-1994 Explorers 27
S 4 inch rough country lift Modified 1991-1994 Explorers 4
C Putting on a 3 inch body lift. Modified 1991-1994 Explorers 35
DUDER 1 5.5 or 6 inch lift with 35" tires pics. Modified 1991-1994 Explorers 29
J want to do two inch lift Modified 1991-1994 Explorers 4
J 2 inch lift Modified 1991-1994 Explorers 1
F Steering binding after 3 inch body lift Modified 1991-1994 Explorers 6
red.EDDIE.4x4 add-a-leaf? SOA? or 4 inch lift leafs? Modified 1991-1994 Explorers 13
T Suggestions for a 2 inch lift on 94 Explorer Modified 1991-1994 Explorers 30
T 6 inch front lift for under $500 Modified 1991-1994 Explorers 34
N 4 inch lift??? Modified 1991-1994 Explorers 13
Hossexplorer 2 inch lift on 93 X-pics? Modified 1991-1994 Explorers 38
1 4 inch lift and 33x12.50 Modified 1991-1994 Explorers 38
Hossexplorer '93 explorer 4 inch lift..Any advice? mpg? Modified 1991-1994 Explorers 31
B 2 inch lift need shocks Modified 1991-1994 Explorers 0
1 4 inch susp. lift Modified 1991-1994 Explorers 37
S 2-4 inch body lift anyone? Modified 1991-1994 Explorers 16
1 4 inch lift 33x12.50? Modified 1991-1994 Explorers 1
1 4 inch trail master lift Modified 1991-1994 Explorers 1
Four0Sport question for those with a 4 inch lift Modified 1991-1994 Explorers 2
9 2 inch lift pics with or without body lift Modified 1991-1994 Explorers 1
9 any one got pic of two inch lift only Modified 1991-1994 Explorers 3
R 3 inch body lift question. Modified 1991-1994 Explorers 9
P 2 inch lift kit Modified 1991-1994 Explorers 20
M 3 inch body lift Modified 1991-1994 Explorers 4
T will 22 inch rims fit without a lift Modified 1991-1994 Explorers 16
T 3 inch body lift stearing extension SOLUTION Modified 1991-1994 Explorers 2
L 1993 Eddie Bauer - 31 Inch tires?? Modified 1991-1994 Explorers 14
T 31 inch tires Modified 1991-1994 Explorers 13
Similar threads
