4 pin to 7 pin adapters. | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership!
    If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
I have a 2005 Ford Explorer XLT 4.0 V6 and bought a trailer with the 7 pin connector. The Explorer has a Class II hitch with the 4 pin. I bought a 4 pin to 7 and 4 pin adapter. I cannot figure out how to install the other wires. I know where each wire goes to but am not sure how to install.
my pos mounty
Land of Corruption
06 F-350
If you bought a trailer with a 7 pin connector and are going to tow this on more than a few occasions, why not add the 7 pin outlet to the back of your truck and wire it up?
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Verno
Waynesboro, TN
94 XLT
Your trailer plug is 7 pin rv plug. You cannot just "connect" it to a 4 pin.
4 Pin is the following: Ground, Tail, Left Turn/Brake, Right Turn/Brake
7 Pin is: Gnd, Pos (+12v), LT, RT, Tail, Trailer Brake, Back up
You will need to wire in a 7 pin plug unlessyour traler does not have backup lights, then you can convert them both to 5 pin round. Also you will need an electric brake controller.
explorerman84
Pine Grove, PA
2005 XLT 4x4
Where can I get a 7 pin wiring harness for my 2005 Explorer?
my pos mounty
Land of Corruption
06 F-350
Check out rental places like U-haul, Ryder and the like. Maybe even Sears. Most rental type places would have it, trailer retail stores, truck accessory places.
sportrac03
Chicago
Explorer Sprtrc 03 XLT
Depending the weight of the trailer a class two can on hold tongue of 350 and total pulling weight of 3500lbs. I would look at putting a class III on your truck especially if you are going tow often.
chad551
St.Louis, MO
2002 Explorer Sport Trac
I have that exact same custom trailer connection setup. I had it made so I could pull my friends trailer and ended up not using it. I will sell you mine if you want it never been used.
Shoot me a PM if interested.
