taxxman2k wrote:
I never said you won't drag them. But if you figure out what you are doing they are strong enough you can still get where ever you want to go and they woun't be your week link. There is alot to be said for driving style, its not all in how well the truck is built but it helps.
I'm actually very confident in my driving abilities, style and I do know what I'm doing, thanks.
You have to admit that the torsion bar drop down bracketry impedes break-over angle. Even when I compensate for the control arms, drop-down diff bracketry up front, and put my tires exactly where I want, there is still sometimes no way around hitting / dragging the torsion bars and their dropped mounts.
The more you hit and drag, the more likely something will bend or break. I'd be able to much more comfortably do more wheeling, and handle more challenging terrain if it wasn't for those torsion bars and dropped torsion bar brackets.
I drag my radius arms but still manage to work around it.
I'd venture to guess that your radius arms are at least a little beefier, and are better, more solidly mounted to the frame than stock torsion bars. When I do my SAS and have a specifically fabricated 4-link, made to handle off road duty, I won't be as concerned about dragging them either...
If you hit the trails all the time then you know the torsion bar drop brackets are the least of what is holding you back on your IFS system.
Overall I agree. However, it would be one less thing to worry about.
But for someone who will hit the trails occasionally and street most of the time its the most cost effective way to go.
I have to agree. It is one of only two kits specifically designed for 96-01 Explores, and the Superift kit is definitely better than the Trailmaster kit because it replaces the knuckles Vs. using extensions. However, if you could get a great price on the RCD front-end lift and use the rear springs from the Superlift kit, it'd probably be the best of both worlds... I'd really love to lose those bars and their mounts. Then I would move on to complain about the CVs...
