You guys are missing a few things:
The 2nd gen Super lift comes with:
-4" Leafs for rear (extended rear brakeline needed if swaybars are disconnected)
-New extended sway bar connects for rear
-2 front drop down brackets for lowwer control arms
-2 front brakeline relocation brakets
-4 New Extended shocks all around
-2 Extended tie rods for steeling linkage
-2 Longer new SPINDLES!!! (most important)
-Optional extended front driveshaft
-2 Extended T-Bar dropdown brakets
-Extended Front Sway bar links (these are crap)
If you are going to keep the t-bars, you are better off just buying the kit (you don't have to buy the rear leaf springs). I work for an aerospace machine shop. We have every tool imagenable and 40 CNC machines. When I do my SAS, yeah I'm gunna fab everything myself, but the time, money, effort, materials, and vehicle downtime just to make a lift with the t-bars won't be worth it (just my opnion). If you have a 4wd you won't be able to get much more travel out of this IFS. Either way, good luck. Have you heard about the RCD kit? If you are going to fab something, check out that kit first.
