You get a good weld flow especially running a mig off of a genset...
I have my moments!! Lol
Thank you! I am learning much from this
My welds will improve, for these pipes the tack welds are done in the truck upside down.... have to hold parts, weld, not get burned, etc
Then the final welds were done on a utv tailgate and it had been a long day.....I know I can do better as I get more practice
Sorry Eddie your truck is the Guinea pig! although if these ever fall apart it will give us a good reason to have a visit
I do plan to wrap the downpipes, I like to use exhaust wrap to push the heat further downstream past the transmission and passenger floorboards
Now that the downpipes are located and mostly sorted out I was able to get back to installing the trans cooler lines, torque converter cover, starter, starter wiring harness and trans wiring harness
Lower trans shield installed! Every little bit counts (sometimes I search for a while just to find the bolts!!)
trans cooler lines, cleaned inside and out, slightly bent to conform to my design
Worked out nicely! I like to use the factory metal lines as opposed to cutting them and running hoses simply because the metal lines do such a good job of dissipating heat, reduce the number of hose clamps, and they are tough
two straight pipes in place to ensure I get the downpipes positioned properly
I am building a few exhaust mounts into the system, first one will be at the trans mount similar to a stock 5.0
you can see cooler lines installed
cooler lines, starter wiring harness installed, do not forget to mount the supports! Hardcore 5.0 dudes will notice for my purpose here I haver moved the trans support bracket to the same bolt as the wiring harness support bracket
That is the underside of the pass engine mount plate
cooler lines in place!
104K starter and starter wiring cleaned and installed. All terminals cleaned and treated with anti corrosion spray
can see the lower trans shield from before is also in, over to the right is our red urethane front diff bushing
another shot of the wiring and cooler line supports, proper routing
the starter / charging harness is mounted to the front of the 5.0 here with these two brackets
transmission cooler lines are wrapped with some heat shield material when in proximity to the exhaust. Remember exhaust downpipes will be wrapped also
Now time to start the wiring for this rig
It all begins at the starter, alternator, ac and low oil level harness from the 98 5.0 104K donor
harness is cleaned and repaired before install
I can use this harness as it is, no mods needed
typical repair of the factory wrap
transmission / 02 sensor harness is getting cleaned up, this dude will need some mods for our build
FYI the wiring harness are the dirtiest part of a build! much time is spent wiping them down so I can work with them
So when Brett built our 4r70w we make sure to use the 98-01 style bulk head wiring connector along with its corresponding internal hard wiring harness and 98-01 style solenoids
Half way through 97 the 4r70w changed from 9 wires to 7. I needed to make sure I had the correct harness/bulkhead fitting before plugging it in
7 wires we have the correct harness, no mods needed
I keep this chart (along with many others) pinned to the wall in the shop because I am often making changes to these transmissions
Now inside the 5.0 transmission harness is also 3 of the 02 sensors. This truck will be using a single wideband 02 sensor with the Holley drivetrain computer....so I removed two of the 02 sensors and their wiring. I will route the bosch 02 sensor to the holley computer using the factory wires and blue plug
time to unpin the removed wires, harness is cut down and 2ea 02 sensors go bye bye
Harness will be re wrapped and installed along with the transmission case vent
stay tuned....more coming almost daily
Today is Friday April 1, the kids are on spring brake next week = WAY MORE SHOP TIME for me
