- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
okay so first up I need to convert the Holley injector harness to use the 98+ style connectors.
Every wire will be soldered on this harness
harness will be tailored to fit the engine bay
holley connectors are removed and factory 5.0 connectors are installed
Holley main harness test fit / installed up the spine of the transmission and into the cab of the truck
Fuel injection harness final wrapped and installed
Crankshaft and Camshaft sensor harness also installed
These are 98-01 style 5.0 injectors, 19# along with the returnless style fuel rail. This will work well with our 07 Ranger style fuel system
crank and cam 5.0 sensors along with their appropriate pigtails.
Wired per Holley chart (and my notes like these)
Now it is time to wire in the Ignition (coil pack) wires. They get integrated into the Holley main harness
per the chart from earlier
These wires get pinned into the Holley PCM connector P1B here
Pull out the white plastic spacers, and add the wires to designated pin locations per chart.
Also you must release the white lock, this will allow pins to slide in and out of connector
press here
unlocked
Ignition coil driver wires going in pins 15-17 and 21-24
Pin 14 is ground distribution from PCM, three wires get combined here
All wires added now, grounds combined
Coil pack wiring integrated!
Now main harness can be installed back into the truck for final time. It slides right in on the passenger side above the header and behind the trans dipstick
wiring laid out over engine, time to clean a bunch of 5.0 parts
press here
unlocked
