- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
I present to you the square mirror modification for 95-01 Explorer, Mountaineer, 02-04 Sport and Sport Trac (and more).
Let’s face it, the old tiny round side
Mirrors are outdated!
The 06-11 Ranger side mirrors are far superior in styling and vision.
After many many years of having explorer and now a daily driven sport trac I got tired of the looks of the old so I did something about it
What this does:
Connects 2006-2011 ford ranger side
Mirrors with your trucks mirror base
This modification requires cutting up two sets of mirrors
Your factory ones
And
The new Ranger mirrors
How I did it:
First up I removed the factory blah mirrors
Remove door panel and speaker to access 11mm mirror mounting nuts and the power wiring harness
Once factory blah Mirror is on bench I grabbed my multi tool. Perfect for chop cut plastic bits. Mirror shown is 2002 explorer sport trac.
We need the mirror base and wiring pigtail
Cut the mounting “peg” off here
I already built a prototype
From Junk yard parts and then the drivers side so I knew where to slice
Now you end up with this
Spend time here to shave the mounting base nice and flat
The blah mirror hits the bottom of the trash can.
Set your now shaved flat base aside and get out your brand spanking new 06-11
Ranger mirror. Available at your local junk yard, or favorite online retailer. I chose some 2010 style, both sides power (to match my sport trac) and these have a snap on “paintable panel” (so they can be body matched)
I have also been known to add muth mirror systems heated glass and led turn signal
Glass and (even birdseye view cameras… but that is for another thread)
Anyways 2010 Ranger passenger mirror
You need to carefully tilt the glass so that the little plastic tabs that hold the mirror to the power base are accessible
I used a very bright led headlight for this, turns out a flathead screwdriver is all that’s needed
Careful here! I broke a Muth mirror once that was a $220 mistake
We end up with this
Now Jump down over our buddy @Stic-o and checkout the rest
What this does:
Your factory ones
And
How I did it:
We end up with this
