DieselHilux
- June 20, 2009
- 95 ford contour
So I started sourcing parts for my 4406 swap, I bought a MANUAL shift 4406 from a 97 F150 (has the speed sensor) to swap into my 97 mountaineer.
I tried shifting it and it seems to work properly, HOWEVER I was looking at the t-case and aside from the indicator light switch, there is another one wire connector coming out the back.
I pulled up a wireing diagram at work and it appears that the manual case has an electromagnetc clutch in it like the electronic ones do.
What is its purpose and is it needed??? When I shifted it manually it seems to shift itno 4x4 without applying power to it, and others have swapped in a 4406 and made no mention of connecting this to anything???
In the diagram, said electromagnetic clutch is controlled by the GEM, via a relay.
Does this have something to do with the fact that F150's have a CAD in the front axle??? It says in the description it is to bring the front driveline up to speed when shifting into 4x4.
Doesnt pulling the lever accomplish the same thing?????
I am confused.....................
