Ok, i am having a problem. I wired all the stereo equipment up(i have installed several systems before). I turn on the radio, and the sub i just installed is getting hardly any power or signal. It moves a little so i know it works. Its just not getting full power. I checked with a volt meter and the amp is getting about 14 volts from the battery. I wired a different speaker to the amp and its getting almost no power to it as well, and its all distorted. Ive checked all the wires and even tried to swap wires out for different ones. The ground has been checked. The only thing i can think of is the low level outputs on my head unit are shot. Is it possible that it would only send out a very weak distorted signal? I have a high level input jack for the amp, i figure thats the last thing i need to check before returning the amp. Im not sure exactly how to wire that up though. It has 3 wires on the adapter plug, what goes to what?
