oldgranola
- March 10, 2013
- seattle
Hello,
I'm posting to get fresh replies and to see if using the AJ1E OD servo replacement actually works. I have a 2002 ford explorer 4L v6 225K ish miles. Now getting a p0775 error, flashing OD light, 1-2 shifting delay/flair. I've read about the housing wear around the OD servo shaft and symptoms such as mine being fixable by replacing the servos with AJ1E's servo replacement kits. Looks doable.
1. What has been the success rate for the AJ1E servo solution? Am I likely to need to replace the solenoid pack with only the p0775 error? I'd think there would be other solenoid related errors if it was stuck etc.
2. Since the housing bores are likely warn and only the p0775 error, I figured it might be reasonable to first change out the servos, see if it goes away and deal with the solenoid pack if needed. Sound reasonable?
3. I also have read of other reasons for the p0775 error such as low tranny fluid, dirty filter. Also pump. I'm afraid of the fluid flush on this old car for the usual reasons. Should I leave that alone or drain and fill, flush and change the filter?
