Stick4503
- December 12, 2011
- Winder, Georgia
- 1996 & 2004Explorer 4x4
I have a 1996 Explorer 4x4 that has the 4r55e. About 2 mile into my drive I had a sudden loss of all gears. Rev the engine while sitting still and the vehicle moves and inch or two forwards or backward depending on drive or reverse. 4x4 engaged same results.
You can feel the transmission engage. The drive shafts turn ever so slightly with heavy depression of accelerator. When in neutral the vehicle rolls as it should.
Just changed out the separator plate gaskets, new filter and fluid to see if this would help but no luck.
No noise or mechanical work done before sudden loss. I realize that I may be in for a new transmission but would really like to make sure the cause is not front or rear end related or transfer case related.
Any help appreciated
