willfargo
- January 24, 2009
- Location
- United States
- Frederick, Colorado
- 1996 Ford Explorer XLT
Summary!:
Input shaft pulled out 3/4" without me knowing and I repeatedly tried to stab engine on to trans with no success. Hired mobile mechanic to come diagnose the issue, he noticed the input shaft sticking out too far... and attempted to HAMMER it in. So.... It is STUCK STUCK STUCK.
I have now been told by others on the forum that it will be jammed into the trans pump which may be damaged and in need of repair or replacement. I don't think the TC was pressed onto the pump so I doub't it got damaged, as the block never got closer than 3/4 inch from the trans
From the research I've now done it looks like the input shaft ends up in the planetary gear for the OD.
I've pulled the bellhousing off, but am too nervous to start pulling bits out of the trans, as I don't want to end up unable to assemble them.
Is there an easy way to get that planetary gear out so I can remove the shaft and inspect the splines for damage?
