Ak Ford
- November 30, 2016
- palmer Alaska
- 1996 Ford Explorer 4.0
New member here. Thanks to this group I've gained a lot of knowledge the past few months. Now, I have an issue with my 1996 ford explorer, That has me stumped. It's 4.0 -4x4 -4r55e. A couple months ago I was driving home from work, Stopped at a light and the engine died before the light tuned green. I started it up in park only to find the engine under load like it was in gear. Turns out that it was. Every gear on the gear selector was now first gear, Even neutral, Park and reverse. It was a long drive home. Ever since then, The transmission was always in forward 1st gear. Needless to say, I didn't drive it anymore.
Now that I have the time to work on it, I ordered a full rebuild kit with all seals, Gaskets, Clutches And bands. So I went ahead and pulled transmission and began the job of rebuilding.
I took my time and made sure everything was thoroughly clean and placed in perfect order with the help of ATSG manual, To the best of my ability. I reinstalled trans and replaced fluid with new fluid, started the engine and finished filling it up to correct level. Now the issue.
I now have park and neutral with no load on engine from transmission. I have good reverse when selected. I have no forward movement in 1st-4th. I actually have reverse when I select 1st.
So; park is park---- reverse is reverse----neutral is neutral----drive and overdrive are no movement ---
--2nd is no movement----1st is reverse.
I have adjusted the bands, Made sure all electrical connectors are clean and plugged in firmly, The OD is not flashing and no trouble codes being thrown. Anyone here have any ideas that would or could help me figure this out? Thanks
