srjohns1
- July 12, 2009
- Lumberton, MS
- 2000 Ranger
I all I have read this fourm for sometime and enjoy it this is the first time to post hope you can help.
I have a 2000 Ranger 3.0 4R55E had it bebuilt about 75K ago worked fine developed a 2-3 flare after it warms up took it to the shop they changed 2 solenoids worked good for about 3 weeks started 2-3 flare again took it back they said it needed rebuilding I brought it home pulled the trainsmission it was clean inside took it apart all clutches looked new the overdrive and int. bands were a little dark, not bad I rebuilt it installed all new bands 2 new servo pistons and a rebuilt valve body from central valve body with updates still have the same problem 2-3 flare when temps gets up. I need help. THANKS
