4R55E to A4LD swap
Gizzard
Payson, Utah
'95 EB
Hi folks. My cousin has a '95 Explorer, apparently with the 4R55E. Trans went out recently. He bought a totalled but complete '94 Explorer, apparently with a A4LD. Trans in '94 had recently been rebuilt. He ASSUMED both trannys are the same. Both trans are still in both vehicles. What are the tell-tale signs that confirm what tranny is what? Can we swap the computer controlled solenoids, etc. from the A4 over to the 4R and make this work? Any help and info is much appreciated.. Don
Glacier991
EF Tranny Guru
Moderator Emeritus
Sacramento, CA 95827
1992 XLT
Look for a vacuum modulator on the side of the trannie near the rear and under the heat shield. It will have a hose running to it. If it is there, you have an A4LD in front of you.
You can swap guts from new to old (mostly) but the cases are different. (See project frankentranny in the sticky threads above) BUT !! You can't put a 4R55 vave body on an A4LD transmission and make it a 4R55 (or 4R44). Sorry.
Gizzard
Payson, Utah
'95 EB
Well, darn it. I will have him look for that vacuum modulator on the '94 tonite. Thanks alot. Don
IAmTodd
4x Explorer Veteran
Johnstown, PA
2015 Jeep
Most likely you're screwed.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
AERBROCONVIL
62910,IL
93 xl star
But can you swap the 4r55 to a A4 application?
and do they sell an upgrade harness?
BrooklynBay
Staff member
Moderator
Brooklyn, NY
MrShorty
Spanish Fork, UT
92 XLT and '87 Bronco II
I don't know if the stand alone controlloer for the 5R55 transmissions will control a 4R55E or not. If it would, that might be the most straightforward way to put a 4R55E in place of an A4LD, even though those stand alone controllers are expensive.
Glacier991
EF Tranny Guru
Moderator Emeritus
1992 XLT
If you have enough $$ there is often a way to make things work. For 99.9% of us we are trying to SAVE $$ not spend it. SWAPS in these days of computer control are $$$ eaters.
vanionBB
Kennewick, WA
Explorer 1996 XLT
Is there a general compatibility thread somewhere, like what transmissions work with what years? I think they put 4r44e and 4r55e in my year (1996) so presumably I could use either in my truck, with very little modification. Is there somewhere that details what year has what tranny and what might be interchangeable?
BrooklynBay
Staff member
Moderator
Brooklyn, NY
