lapetec
- February 3, 2011
- Coshocton, Oh
- 1996 Explorer XLT
96 Exp XLT, 4R55E
P0756 Shift Solenoid B Performance or Stuck Off
I've read a lot about code P0756 on this forum but still not sure where to start.
The trouble started with the trans not wanting to shift in to 2 gear until you let off the accelerator.
After a few miles the OD/Off light starts flashing and then get a hard shift into 2nd. 3rd and 4th gears seem to shift normally.
There seems to be no engine braking in 1st or 2nd gears and doesn't want to down shift to 1st under acceleration.
Strangely. sometimes it will shift into 2nd gear normally when accelerating up a hill!
Today after a long drive it stopped shifting up from 1st at all. I discovered if I shut the engine off
(resetting the computer) and restarting the engine the trans will up shift with the same symptoms as above.
Recommendations please.
bump
bump
