Spdrcer34
- March 14, 2002
- Bremerton, WA
- 1992 Explorer XL
I bought a 1998 Mountaineer for my wife off craigslist, that thread is here: http://www.explorerforum.com/forums/showthread.php?t=300228
The Mounty shifts fine from 1-2, and 2-1...but it doesn't shift into 3rd or OD. I tried swapping the electric shift solenoid, and it does the exact same thing. So I believe the direct drum is toast. It is probably the most common failure of this otherwise notoriously reliable transmission.
After reading this thread written by Glacier991: http://www.explorerforum.com/forums/showthread.php?t=128800 and all of it's sub threads....and when I say I read them, I more or less MEMORIZED THEM by reading them 10-15 times each. I was convinced I could re-build the transmission, and even including the new tools I needed to buy, I could do it for less than the $1850 I was quoted locally to get it done.
I have purcchased, or already had the following tools:
Lip Seal protector set (seen in various posts/pictures, here are a couple)
Pilot Bushing Puller
Clutch Spring Compressor
I also just bought THIS spring compressor:
Rear Case Bushing R & R Tool
Direct Drive Solid Sealing Ring Installer Kit
I have also purchased a new Digital 6" Caliper, and the 4r70W manual from ATSG...
Now I still need to source the following parts:
Small tipped snap ring pliers:
I still need to buy that bowl shaped spring compressor, once I have everything here, I will make a build diary like Glacier991 did..
Ryan
Ryan
