JoshT
- January 15, 2011
- Middle Georgia
- 1999 Ranger
So automagic transmissions are out of my wheelhouse. I understad the concept at a very high level, but for the most part it's just magic. I don't really even know where to begin on troubleshooting transmission problems or sometimes evenif a problem is caused by the transmission.
What I've got is a 2000 Explorer 5.0L AWD drivetrain swapped into my 99 Ranger. Engine is fresh rebuilt, solid, tuned, and appears to be sorted. I do not believe that the issue started with the fresh engine, but didn't drive it much before the fresh engine to have a reference point. The transmission is original 180K+ mile Explorer AWD 4R70W. Only things changed on trans are new fluid and filter with the swap.
What I'm experienceing I can best relate to a manual transmission to describe. You know when driving a manual if you have the transmission in too high of gear for the speeds it'll buck or shudder. That's kind of what this feels like, but fairly light. Most noticable conditions are at 40-45 MPH on flat level ground with just enough throttle applied to maintain speed. If you open throttle to acellerate any it goes away, if you let off throttle it goes away. At this speed if you turn off OD it also goes away.
Happens at some other speeds too under same conditions, but that 40-45 range is most noticable.
I suppose it feels like lightly lugging the engine. In a manual trans I'd downshift, but an automatic isn't supposed to require manually downshifting (or turning off OD). I'm fairly sure that the culprit is something to do with transmission, whether it is something worn out, or shift points need adjusting in the tune. I have no idea where to begin on diagnosing and fixing.
I'd love to just say no driving at those speeds, a Sammy Hagar solution. Unfortunately given speed limits and places I regularly drive, that isn't an option. I'm just not sure how to advance on diagnosing and fixing.
FWIW, a shift kit (or J-mod) is in the plans for the future, but don't want to invest that into this transmission if I'll be replacing/rebuilding it in short order. Not to mention if there is a non-valvebody related problem, those modifications would likely acellerate the need for repalcement. On the flip side, if it is valvebody related, the shift kit modifications and reseal may fix it getting more life out of this transmission.
