The best way I’ve found is installing a Superior “Tuff Plate” no drilling or tapping plus its much thicker than OEM. If you end up pulling the unit and are going to replace forward drum stay clear with stuff made in China.
Brad
Well, well... look what we have here...
The Superior "Super Tuff" plate K092 lists "Late 2000+" or " 2001+", mine is an EARLY 2000.
My valvebody is the '98-'00 F094
The ’98-’00 will has a hole inside the small plate.
The Super Tuff Plate K092 is for the '01+ F095 valvebody, it has a hole just to the rear of the small plate.
Is this a "Disqualifier"?
Should I get a 2001 valve body? I know the 2001 4R70W used the 2000 case for at least 2001, probably longer.
Also, after checking the J-MOD/Baumann directions, this K092 plate IS a shift kit!
The holes are J-MOD or larger almost across the board.
The Baumann directions already has the plate at a Level-3 (or better!).
Obviously there's more to a shift kit than just the oriface sizes in the plate, but that was a big surprise!
Is the 2001 4R70W that big of an upgrade?
