engineeering
- July 3, 2014
- 06 explorer xlt 4x4
Ok. This is NOT a how to. I will be working through this over the next 4 months and will be looking for advise/recommendations etc. During this time... I will be posting updates etc. Once completed, I will do a "how-to" write-up and include the link at the end of this "progress thread".
Now that I've "clinked the glass" to this project... I'm determined to make it happen to my Explorer 4th Gen 4WD 2006 4.0L before the year ends (with an approx $2000 budget). So my buddy said he would lend me his 4.0L Ranger 4WD Manual 4.0L (with the M5OD) for the next few months so I can compare trucks and have something to drive in the interim.
So, I did some digging over the past week and I know what needs to be done. I predict I will have the most issues with the manual pedal installation and the wiring of the reverse lights/ignition lock disengage switch (from the auto trans).
Here are a few things I have yet to confirm:
(1) What's different between my t-case assembly and the Rangers?
(2) Are the t-case motors the same? If so, I guess just the plug is different? ...hoping I can just swap/re-wire the plugs for the t-case
(3) Hoping to use the same wiring harness and just wire up the park ignition switch to the manual pedal (or dummy/bypass wire it). ...we will see
(4) Will be using the same ecu as it should be able to operate the motor without a problem. As for the transmission codes... I hope I can disable them via a custom SCT flash (I have an X4 handheld and plan to use a performance tune shop to program it)
(5) The centre console already has the floor shifter. Unfortunately the stick will probably move more than is allowed in the stock space. I will probably need to modify and/or lift the shift stick.
...updates to follow
