4th gen body lift is installed!!!!!!! | Page 2 | Ford Explorer Forums - Serious Explorations
24s on an Explorer?!? Noooooo! I beg of you not to do such! :D
Oh man I love my rims. I just want a 4wd to lift up and go crazy with. With the 2wd I am very limited on what I can do and tackle. But I love my truck lifted. I just dont have the money to do a 4wd conversion and I am not selling this truck. . . So lower it goes until I can get enough cash to buy an older used 2door X.
i love the look of your rig. great job :)
Thank you I appreciate it. It was a lot of hard work but I love working on the x. Makes me feel all warm and fuzzy. lol. Well tomorrow down he goes a little. still keeping the32's until they wear out.
Just completed a 1" body lift:
No steering shaft extension, no fan shroud trimming, no front bumper brackets, and no cutting of the back bumper needed. Just ordered new bolts and some 2" lift blocks which I cut in half. I will be welding a bit of 1" square steel tube on top of the rear bumper reinforcement to fill in the barely noticeable gap and to have something solid under the bumper cover so I can stand on it and have it be sturdy.
Old thread but can anyone tell me what ranger body kit I should use to do a 07 body lift.
PA883 is the kit, but since you aren't going to be using the bumper brackets, bolts, or pretty much anything else that comes in it, you might as well just buy 3" lift blocks, make your own brackets, and buy the bolts separate.
I wish your photo was still linked. I want to see the look of a 1" lift. I just got a 2010 EB 4x4 and I want to lift it a little, but I don't want to go crazy.
Bump.
I'm with you Snooker. New pixs link pls!
Writeup!
FIRST I AM NOT LIABLE FOR ANY DAMAGES INCURRED TO YOUR VEHICLE YOURSELF OR OTHERS WHO
MAY BE HELPING YOU THROUGHOUT THIS PROCESS. I AM NOT LIABLE FOR ANY DAMAGES TO ANY
EQUIPMENT OR PROPERTY FOR YOUR NEGLIGENCE. THIS IS A GUIDE TO HELP YOU THROUGH A PIA
BODY LIFT. NOT ANOTHER EXCUSE TO SUE SOMEONE. START THIS PROJECT AT YOUR OWN RISK!
Hey guys here is the writeup for the three inch body lift for 4th gens. I did some
modifications to the front bumper(ill explain more later) and the steering extention.
If you start this project and find another way let me know and ill update as neeeded.
You will need for this project
Performance Accessory 883.
8 pucks
8 Bolts ( 6 medium length i think 180mm) and two long (200mm)
8 nuts(the bolts do not thread into the "pucks" we have so nuts are needed.
Assortment of sockets and wrenches and extentions
Air gun (I dont know how this could be done without it) Would take twice as long
Air ratchet
Breaker Bar
Dremmel(trim fan shroud)
Drill( hole needed in steering shaft)
Washers(I needed 5 just to be on the safe side)
Locktite
Razor blade(if you dont want to remove rear seats)
Jack(s)/Lift(Lift body off frame
Wood(To help get jack high enough) THIS STEP BE EXTREMELY CAREFUL! ALWAYS USE JACK
STANDS OR MULTIPLE JACKS!
Flathead screwdriver
prybar
flashlight
Another person(Cannot be done alone)
Liquids( you will sweat your ass off) Preferably non alcoholic since you are lifting a
body off of a frame and you need to be sober as you do not want to incurr any
injuries.
AGAIN I AM NOT LIABLE FOR ANY DAMAGES EXPRESSED OR IMPLIED AGAINST PERSON, VEHICLE,
PROPERTY, TOOLS, ETC... CONTINUE AT YOUR OWN RISK!!!!!!!!!
The first thing is go get 8 nuts to fit the bolts. You WILL NEED THEM.
Disconnect the battery.
Then I removed the font bumper. For this you need to pop the hood and take out the top 5-6 black push clips. They have Phillips head screws on them. After that you need to take out the headlights. There should be two easy visible bolts and one toward the bottom which you do not have to take out completely. You can if you want to. Then just pull toward you and they should pop out. Make sure to disconnect all the electrical that comes with it. Underneath the bumper there are two more clips to take out. On the Eddie Bauer edition is under the tan trim piece in the center. Also you need to take out the front part of the splash guards in the wheel well. Two or three Phillips head screws and a couple push clips. After that the left and right side where the bumper meets the fender there are more clips, just pull and they should pop and your bumper is off.
To take out the metal part(actual bumper underneath plastic “bumper” There are just four bolts and it slips right out. You will need these bolts again later.
I then undid the steering bracket. Its on the drivers steering wheel shaft right near the firewall. Its just a universal joint. This is where the steering extension comes into play. The male end of the steering extension that comes in the kit is rounded and the other side is flat. You need to file down the rounded end to be flat. Be careful not to take too much off. Then take the female end and mate it up with the steering shaft on your x. Find out where the hole is and drill a hole in the steering shaft in your x. After all is said and done just mate everything up and locktite the crap out of everything. If this part fails you will most likely die. So Take your time on this part. Better take too long and be safe than half ass it and lose steering on the highway at 65mph.
To remove rear bumper- more black plastic clips. Should be about 10-15. I didn’t feel like counting again. But after you remove these take out your tail lights. Remove all electrical and there should be three bolts inside on the bottom. Only take out ONE closest to you. You can tell its attached to the bumper. Should be 8mm. Now go underneath the truck and on the left and right side there are two more small bolts, one on each side 7mm I think. Take these out and GENTLY slide the bumper off. GENTLY, I say this because there is a electrical clip on the right side that needs to be disconnected.
There are two body mounts in the front of the X. One in front of the drivers seat by the emergency brake and another on the passenger side. There are two more just behind the drivers seat and passenger seat. There are another two under the rear seats. There are also two in the back under the storage units. All are underneath black oval shaped rubber grommets. Start by lubricating ALL mounts. Trust me it will make it way easier. I used a full can of wd40.
Before you start lifting your X’s either trim the fan shroud three inches while under the truck or take out the shroud which is a PIA. I just cut out three inches while underneath. The dremmel works great for this. Make sure you are wearing eye protection. The “Shrapnel” that comes off the shroud is hot and no bueno when you get it in your eye.
You will also need to either remove the rear seats or cut the carpet to get to the body mounts under the rear seats. I just removed the seats. There were 12 Bolts and they just came right out.
Now you can start removing the bolts on the body mounts. Here is where the extra wrenches or pry bar come into play as well as the impact gun. Everyone has heard of these “pucks” That spin when you try to remove the body bolt. Use a friend and a pry bar to jam in between the frame and “puck” and give it hell with the impact gun. The hardest ones for me were the rear pucks and the ones underneath the rear seats. After you remove all the bolts I started on the rear.
I lifted with blocks of wood on top of a jack. BE CAREFUL. If you notice that the jack is moving or the wood may give way either move out of the way or if you have time lower the jack and start over. Jack up the rear and insert plastic lifts. Start using the smallest bolts. I don’t remember which ones I used but always start with smallest. If the smallest fits great if not go up to the next size. The longest bolts are to be used for the bolts in font of the drivers seat. After all the bolts are in GO BACK and locktite all the bolts and tighten them down with the Nuts you bought from your local hardware store.
You can now assemble the rear bumper. Unfortunately our actual metal bumper is welded on to the frame so you will have to either make a 3” bracket and cut the bumper off the weld it 3”s higher or leave it be and have a little bit of a gap showing. This is what I did since I do not have access to a welder yet. It doesn’t look terrible. Only shows where the hole is the hitch. Everything else is covered. I was almost thinking of cutting my exhaust and re-routing it where this gap is. But that’s for another day.
The front bumper sucks. Plain and simple. The brackets that are provided in the kit will work with modifications to the metal bumper. Or you will need to fabricate new brackets. I decided to modify. Hook up the brackets for mock up and draw where you need to cut the bottom bumper. Should be about 6-8 inches where the plastic bumper screws into the metal one. This part will need to be cut off. You will see what I mean when you get to it. A 3” cutoff wheel works just fine. After you cut this section off of both sides you can now install the front metal bumper and the plastic bumper over it. Re-install lights and battery. This concludes the lifting of your 4th Gen Explorer.
You will have enough slack in your brake lines and everything else. Just when you are lifting make sure you are not catching anything.
I’m Sure a lot of you are thinking that the bumper will not seat properly… Well, unfortunately you are right. Mine is seated and looks just as good as stock. There are a few gaps that I don’t like but it does not affect the performance. You cannot tell just by walking past and looking you would have to get up close and check it out. But, I drove 150 miles at 80 miles an hour and it works just fine.
Ill post some pics in a day or so. Just got really sick and work is a PIA. Hope this helps anyone wanting to lift their X a little more.
I know I’m a decade late, but I am going to throw this question out hoping someone here can answer. I have a 2006 Explorer EB 4x4. I currently have a 3” front 3” rear suspension lift with the BTF upper control arms. I am thinking of adding a few more inches 2”-3” body lift.
Here is my question, brake lines, will I need to extend them? Steering wheel extension, if I was to do a 2” or 3” lift, how much of an extension? Basically, what problems will I have on top of the regular body lift problems?
