Greg_DonWindsor
- February 25, 2007
- Calgary, Alberta
- 2008 Limited V8 4x4
Hey guys,
this is my 2nd explorer and second aftermarket stereo build. Started out with the installation linked at my post over in the modified 4th gen forum:
New 2008 Limited project truck
Basically, I’ve installed a Pioneer DMH-W4660NEX headunit with PAC harness, and JL C2-570x coaxial speakers in all 4 doors with dynamat insulation. If it helps to know, I did this in stages; ran factory headunit with front JL drivers installed, then added the rear JL drivers a few months later. A few months after that I installed the pioneer headunit.
Everything was running great for a while, although I noticed there seemed to be no sound coming from the factory 8” sub, there was no such sub wire connection to be found on the PAC harness. The sub also seemed as if it was “ghosting” output at a very low volume from the headunit built in am/fm or satellite radio, it was too quiet to be sure. This problem persists.
Lately, I had an issue with front left driver cutout from time to time. Then after a bit longer front right started to cut out from time to time. Now both front speakers are out. Anyone have any ideas as to what the cause might be? I’ve removed the headunit and all drivers a few times already searching for it and checking connections but with no luck so far. I had been thinking of getting a 5-channel amp and aftermarket sub to finish it all, but I’d like to solve this door speaker driver issue first.
Thanks for any help in advance!
-Greg
-Greg
