239
- April 4, 2011
- Bonita Springs, FL
- 2000 XLT, V6 OHV
Does the 4WD 5R55E deep pan bolt on to the 2WD 5R55E? I want to add a transmission fluid temperature sensor the next time I change my fluid. Any issues if I switch over to the deeper pan? I know I’ll have to use a longer filter too.
I plan to use a pan with a drain bolt like this:
Then I’ll just use an adapter for the temperature sensor where the drain bolt would go:
I’m adding a coolant temperature sensor this weekend and will have an extra spot in the gauge pod for the transmission temperature sensor. Thanks for any input.
