4x4 and tranny issues
lynnboy021
billerica ma
2004 explorer
first lets start off with the 4x4...my 4x4 high light flashes 10 times then off for a min or two.. if i press the 4x4 high you can hear the t-case motor switch to 4x4H and if i press 4x4L you can hear it switch to 4x4L so i know the motor is working... i looked up online and people said that the ground wire next to the case can be broken but it seems to look ok... hooked up my scanner and i get code P1824 4-wheel drive clutch relay circuit...
now to the trans.. i did a trans filter and fluid change and the fluid was really good nice and red and no bernt smell to it... so my problems i am having is, 1. i get a whine when starting up the truck. maybe air is getting in the tranny? 2. trans shifts fine and smooth but when down shifting from 2 to 1 kinda has a small kick. maybe from trans or driveshaft? maybe needs more fluid? i dont get no codes or no o/d light on....
2004 xlt
  • Like
Reactions: imp
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
2004 xlt
@lynnboy021
First, depressing the 4X4 HIGH button does NOTHING with the t-case motor, which ONLY shifts t-case into and out of 4X4 LOW. 4X4 HIGH is a SWITCH which turns on an electronic clutch in the t-case. When 4X4 AUTO is depressed as in all normal driving, the clutch is controlled automatically to engage upon detected wheel slip, and at that ONLY with slip present.
P1824 tells you something is haywire with the relays, 2 of them, mounted on the upper-right-hand fender lip in the back. These relays drive the shift motor to engage and disengage 4X4 LOW ONLY.
lynnboy021
billerica ma
2004 explorer
I will check the relays... really just more worried about the trans..
J Tranny Swap 4x4 High Flashing Stock 2002 - 2005 Explorers 7
C AWD vs 4x4 tranny differences Stock 2002 - 2005 Explorers 0
D Tranny Rebuild now no 4x4? Stock 2002 - 2005 Explorers 9
H 2002 XLT 4x4 tranny slipping and whining Stock 2002 - 2005 Explorers 5
W 2002 Explorer XLT 4x4 Tranny Stock 2002 - 2005 Explorers 1
0 4x4 Problem or Tranny? Stock 2002 - 2005 Explorers 4
S 02 XLS 4x4 121K miles Tranny shutter Stock 2002 - 2005 Explorers 7
A Tranny and 4x4 Problems Stock 2002 - 2005 Explorers 15
KA3NXN 4X4 Transfer Case Control Module Stock 2002 - 2005 Explorers 3
S Please Help, 2002 standard 4x4 explorer wont go into gear when started Stock 2002 - 2005 Explorers 10
M Transmission 2004 XLT 4x4 WTF? Stock 2002 - 2005 Explorers 2
R 2002 Explorer 4x4 4.0 , turn off OD for flashing OD light help? Stock 2002 - 2005 Explorers 4
J 4x4 Problems on 2002 Explorer Stock 2002 - 2005 Explorers 7
M transmission wiring harness 2005 explorer xlt 4.0l 4x4 Stock 2002 - 2005 Explorers 0
L 4x4 blinking Stock 2002 - 2005 Explorers 0
J 02 EXPLORER 4X4 HIGH LIGHT FLASHING Stock 2002 - 2005 Explorers 2
K 4x4 Light stuck on Low Stock 2002 - 2005 Explorers 12
R 2002 Eddie Bauer 4x4 explorer Stock 2002 - 2005 Explorers 3
S Understanding 4x4 Operation NonOperation 2002 XLT Stock 2002 - 2005 Explorers 19
R 2003 XLT 4.6 4x4 shield mounted on transfer case Stock 2002 - 2005 Explorers 7
L 4X4 Control Module Stock 2002 - 2005 Explorers 1
F 02 Explorer XLT 4x4 Eddie Bauer issues Stock 2002 - 2005 Explorers 7
T Issue with 4x4 buttons 02 Explorer Stock 2002 - 2005 Explorers 5
R Wheels get stuck 4x4 issue? Stock 2002 - 2005 Explorers 5
C 03 2x4 to 4x4 trans swap Stock 2002 - 2005 Explorers 3
D 4x4 control upgraded module Stock 2002 - 2005 Explorers 2
B flashing 4x4 high light Stock 2002 - 2005 Explorers 0
M 2002 4x4 engagement Stock 2002 - 2005 Explorers 0
R Newbie - WI with 03' Ford Explorer XLT 4.6L V8 4x4 - Airbag Light Stock 2002 - 2005 Explorers 0
R 05 explorer 4.6 4x4 whining & thumping Stock 2002 - 2005 Explorers 3
S 04' Explorer stuck in 4x4 Stock 2002 - 2005 Explorers 0
R 05 ford explorer 4.6 V8 4x4 turns over but not start Stock 2002 - 2005 Explorers 1
D 04 Explorer 4.0L 4x4 - cruise inop, brake lights stay on Stock 2002 - 2005 Explorers 1
N 4x4 auto, 2004 explorer Stock 2002 - 2005 Explorers 7
L bought a 2005 exp EB 4.6 4x4 Stock 2002 - 2005 Explorers 8
G 2005 FORD EXPLORER 4X4 SHIFT ISSUES Stock 2002 - 2005 Explorers 6
0 2003 XLT 4x4 U-Joints Stock 2002 - 2005 Explorers 1
M ABS locked, Traction Control off and 4X4 high flashing? Stock 2002 - 2005 Explorers 2
R 2004 NBX 4x4 drive train mystery...can someone help with the diagnosis? Stock 2002 - 2005 Explorers 5
D 2002 4x4 issues Stock 2002 - 2005 Explorers 4
K Trouble with 4x4 Low Stock 2002 - 2005 Explorers 0
B Stuck in 4x4 low Stock 2002 - 2005 Explorers 3
F 2002 Frod Explorer XLT 4x4 Stock 2002 - 2005 Explorers 2
F 2002 ford explorer XLT 4x4 no air will blow threw vents only threw defrost Stock 2002 - 2005 Explorers 2
J 2002 Explorer 4x4 stuck in low, new module and shift motor Stock 2002 - 2005 Explorers 2
G Much Needed Help Regarding 4x4 Stock 2002 - 2005 Explorers 9
X 4x4 high and O/D light flashing Stock 2002 - 2005 Explorers 3
C No 4x4, no brake lights, can not shift out of park... Stock 2002 - 2005 Explorers 8
M 4.0 sohc engine TTY bolts 05 explorer 4x4 Stock 2002 - 2005 Explorers 2
A 05 G3 4x4 LTD - Turn signals, brake lights, dash lights acting up Stock 2002 - 2005 Explorers 3
Similar threads
