done it all, still no 4wd
:roll: Okay I'll try that. Thanks! But while I'm here, I just composed this entry for another thread and thought I'd paste it here in case it doesn't work:
I've been out of the loop for a awhile, but I still need to fix my four wheel drive. Here's a play by play of what I've done:
I've followed all of the above advice in this thread. I took the motor off, dissasembled, cleaned it, and connected it to the battery while off the truck. It seems to work fine. My Ranger is a 98, but it only has 68 K miles--mostly California and mostly city miles--so the actuator motor was considerably cleaner than those pictured in the above thread. I also powered it directly from the battery while it was installed on the transfer case and it seemed to shift the between 2 high and 4 low easily. All this leads me to believe I have and electrical problem between the dash witch and the switch on the actuator motor (the disc that recieves the wire harness). This points me to what Richard F wrote earlier in the thread about a processor board and a diagnostic procedure. But his "serious explorations" are on an Explorer and I can't find this processor board on my Ranger. Has anyone ever been down this road with a Ranger? Here's what Richard F wrote:
"I was having some trouble with my 1991 Ford Explorer transfer case and talked with a service tech up hear in Alaska about it. He told me about a test you can perform to the processor board that is located in the rear left access panel next to the jack and rear windshield washer container. In has 2- wire harness pin connectors attached to it on the left side. If you remove the 2- wire harness pin connectors and turn on your ignition switch. Now you can push the white square button on the bottom edge of the processor board and it will turn on a red LED right next to the button. If the red light flashes this means you have a problem with your actuator motor assembly. If the red light stays bright this means you have a problem with the processor board."
Additionally I did the ohmeter tests reccomended at the beginning of the thread. In both the 2wd and 4low positions there was one discrepancy, where it showed continuity and ,according to the following info, it shouldn't have. Does this point me towards the switch on the actuator motor? The Processor board? The switch at the dash? Here's the ohmeter tests from above:
"In 2WD position, pin 10 (yel/wht, circuit 762) should show continuity with pin 6 (violet, circuit 771) and continuity with pin 8 (brn/wht, circuit 764), and should show no continuity with pin 7 (white, circuit 770) and no continuity with pin 9 (org/wht, circuit 763)
In the 4WD/Low position, pin 10 (yel/wht, circuit 762) should show continuity with pin 6 (violet, circuit 771) and continuity with pin 7 (white, circuit 770), and show no continuity with pin 8 (brn/wht, circuit 764), and no continuity with pin 9 (org/wht, circuit 763)"
Finally, when I do try to use the dash switch it performs as the manual says a system that needs service should. There's a click from the dash. Then the 2high and 2low lights flash 6 or seven times every 5 or 10 minutes for probably, twelve hours of driving time. Since there's a click, and the lights are reacting to the dash dial switch, does this mean it's the processor that's confused? The switch on the actuator motor? Please help!!
