pugsy
- October 10, 2005
- Toronto, ON
- '92 XLT 4x4 (4 door)
K...I need a quick tutorial on how the 4x4 works on these explorers. Just got a new shift motor ($150 CDN. for brand new - sweet deal) so now the lights come on when i push the buttons.
So, now for the tutorial, someone tell me if I'm correct or where I'm wrong.
- in 2 hi, when in neutral and i roll the truck, the front driveshaft and axles don't move - as expected.
- when i push 4x4 and the light comes on, when in neutral and i roll the truck, the front drive shaft and axles now rotate, this means the transfer case is working right and the engine will be powering the front axles, right? However, I'm not sure my hubs are locking cause after I drive forward a bit, then put it back to 2 hi, the axles don't spin anymore. If the hubs are locked and it's in 2 hi, the axles and front drive shaft should still rotate right?
So, my conclusion is that that auto hubs are not engaging right. I need to get out to a sandy road to test it out. They have a lot of grease in them so was thinking of cleaning them out to see if it helps.
How long does it take for the auto hubs to lock? I know that once they lock, if you want to unlock them, to drive in reverse for a few feet.
Anyhow....thanks for the lesson on 4x4. I've only ever had 4x2's.
