4x4 lifting
ncarrier0102
Walkertown, N.C.
'93 xlt 4x4
:exp: I was wondering if anyone out there knows the easiest and cheepest way to give a 93 explorer and 2" to 4" lift, weather it be a body lift or suspension. it dosen't matter to me. I am not looking to spend a lot on it for one and for two my family sometimes will still ride in it. I just want to be able to take it in the woods and play around a little. I have installed an k+n filter in it and ran dual exhauste to make it sound better. now I want it to look as "mean" as it sounds. please let me know.
thank you,
nathan :D
ace.skinner
oskaloosa, IA
'91 XLT 4x4
Me Too, Me Too! I Really Want A Good But Not God'y Lift, Who Sells The Cheapest Rear Axle Flip Kit And Should I Even Flip It? Should I Just Add A Leaf And Some Drop Shackles? Show Me The Way Of The Jedi! '91 Explorer Xlt 4x4.
Lt.Jim
South Central Pennsylvania/NorthernMaryland
94 XLT
For a first gen explorer the cheapest suspension lift is the f150 spacers up front and shackles and/or add a leaf in back. This will net you about 1.5inches of lift. You can also get a 2 or 3 inch body lift.
F150 spacers are about $13 each
aals are about $35
War153 shackles are about $65
2 or 3 inch body lift are around $125
With the spacers up front you will also need an alignment!
Glen4X4
Lewistown, Pa
2000 XLS
Welcome To The Forum!
Dopler174
Official Welcome Committe
Moderator Emeritus
Greensboro, NC
1993 XLT 4X4
aals are about $35
This is the cheapest way.
ncarrier0102
Walkertown, N.C.
'93 xlt 4x4
thank you all for the welcomeing. I was wondering if you (Lt Jim or Dolper174) know of a website to purchase said items you were talking about? or maybe someplace that does it cheep? i went to Kelly's Bar and Grills in Kernersville and they wanted a little over $500 for just a 3" inch body lift. labor and parts included. not sure if that is a good deal or not. please let me know. also what about autohubs v/s manual? should i put manual on or leave the auto's on. what is your oppion?
crafty_23456
lacrosse, WI
93 Explorer EB
Hey,
I would normally say to do the body lift yourself and it would cost about 140-150$ and take 5-20 hours depnding on how good you are and how rusty your X may be, but for 350$ labor I would let them have fun with my rusted together explorer.
The suspension lift on my X was just under 200$ w/ skyjacker lift springs, add-a-leafs and the warrior shackles and got 2.5" in front and about 3" in the back. It was alot easier than a body lift would be on a truck as rusty as mine and only took 6 hours.
When my autohubs started failing I put in the warn manuals and I like them much better. Much more reliable, the autos didnt work all that well the entire time I had them. But if you dont use 4x4 alot and dont want to get out of your vehicle every time you want to engage/disengage it then keep the autos.
and welcome to the forum!
ace.skinner
oskaloosa, IA
'91 XLT 4x4
thanks for the info. do you think 4wheel parts would have that lift? :exporange
454burb87
Yorba Linda, CA
91 XLT 4x4
Four Wheel Parts
They do have the skyjacker lift kits mentioned. It is a 1.5-2" lift kit with new front springs, rear add-a-leaf and 4 hydro shocks. The kit retails around $419.00. From what i have heard skyjacker is flexy and comfortable.
As far as a body lift goes they offer a 2" and a 3". These kits include: bolts, bushings, steering extention and bumper bracketry for around $140.00-$180.00.
hope this helps
Lt.Jim
94 XLT
ncarrier0102
Walkertown, N.C.
'93 xlt 4x4
ty i will checl it all out.
Blue m&m 4x4 Working Properly??? Modified 1991-1994 Explorers 10
M 94 EXPLORER 4x4 MODIFICATIONS HELP Modified 1991-1994 Explorers 10
allmyEXes Slightly Modified-1991 Explorer 4 dr 4x4 Build Modified 1991-1994 Explorers 19
Z Need help with 4x4 issue Modified 1991-1994 Explorers 10
allmyEXes 1991 Explorer 4dr 4x4 radiator option Modified 1991-1994 Explorers 2
1 4x4 going to the crusher Modified 1991-1994 Explorers 2
R 1993 4x4 manual to auto swap? Modified 1991-1994 Explorers 20
R Have 2 shifters? 1993 xlt manual 4x4 Modified 1991-1994 Explorers 2
F No low range or 4x4 lights Modified 1991-1994 Explorers 7
8 Two builds in one- 93 4x4 Prerunner and a DD 2000 5.0 Modified 1991-1994 Explorers 7
O 91 4x4 sport overhaul. Modified 1991-1994 Explorers 6
X Planning a V8 swap in my 93 sport 4x4 5spd Modified 1991-1994 Explorers 2
J 1991 exploder 4 inch lift. 4x4 problems Modified 1991-1994 Explorers 7
S 93 Explorer Limited 4x4 Ford am,fm,cass,cd Modified 1991-1994 Explorers 4
S 93 Explorer Limited 4x4 exhaust Modified 1991-1994 Explorers 1
P KinG ArieS CuStoM Ford 4X4 Explorer Modified 1991-1994 Explorers 0
8 Dora- The Prerunner 4x4 DD Build Modified 1991-1994 Explorers 13
D 4x4 help please Modified 1991-1994 Explorers 1
F Need help, 4x4 control module rewiring Modified 1991-1994 Explorers 1
R A4LD performance 4x4 trans Modified 1991-1994 Explorers 4
G 4x4 problems 1994 ford explorer Modified 1991-1994 Explorers 1
M 4x4 issues after M5OD swap Modified 1991-1994 Explorers 18
K 1994 4x4 Engine Transmission swap ideas Modified 1991-1994 Explorers 69
B 92 4x4 axle swap options? Modified 1991-1994 Explorers 3
O here is my 94' Explorer XLT 4x4 Modified 1991-1994 Explorers 10
D 1994 ford ranger 5.0 4x4 NEED HELP!! Modified 1991-1994 Explorers 0
4 4X4 Issue help and input please! Modified 1991-1994 Explorers 8
E truck wont go out of 4x4 Modified 1991-1994 Explorers 13
D My Build Thread 93' 4x4 Modified 1991-1994 Explorers 2
T 2wd conversion to 4x4 Modified 1991-1994 Explorers 32
F Tie Rods Recommendations for 91 4x4 XL Modified 1991-1994 Explorers 17
R Problem with my 4x4 Modified 1991-1994 Explorers 16
B 4x4 explorer front end conversion Modified 1991-1994 Explorers 4
K How do i change a 4x4 into rwd only ? Modified 1991-1994 Explorers 12
J 4x4 questions? Modified 1991-1994 Explorers 19
9 Hot to fix 4x4 Modified 1991-1994 Explorers 6
T a4ld 2x4 to 5 speed 4x4 swap questions Modified 1991-1994 Explorers 3
T 4x4 Manual Hub Conversion Modified 1991-1994 Explorers 24
M Can an Explorers 4X4 be put onto a Ranger 4X2? Modified 1991-1994 Explorers 17
MrQ Connecting 4x4 Lights Modified 1991-1994 Explorers 0
R got some 4x4 problems need ideas Modified 1991-1994 Explorers 8
S 4x4 wont work under a load Modified 1991-1994 Explorers 3
1 need help with 4x4 driveline in sanford nc. Modified 1991-1994 Explorers 10
G 91 Sploder sport 4x4 thread Modified 1991-1994 Explorers 59
I 1993 Prerunner 4x4 Explorer Modified 1991-1994 Explorers 9
R 1st Gen X Sport 4x4 Pics Modified 1991-1994 Explorers 6
M BRAKES ON 94 Explorer 4x4 Modified 1991-1994 Explorers 7
J my 4x4 will not engage properly Modified 1991-1994 Explorers 3
P please help!! front end "pop" in 4x4 Modified 1991-1994 Explorers 8
1 4x4 problem Modified 1991-1994 Explorers 4
Similar threads
