2003vstrom
- August 14, 2009
- coldwater,michigan
- 2014 Explorer Limited 4X4
hi guys I got a sweet deal on a 2002 explorer 4x4 limited with everything on it side airbags, message center, dual climate, black leather, moon roof, etc. I have 15 years of exp. of work on truck and cars, anyways when you start it, all of the lights on the gauge cluster light up like they suppose too, but the 4x4 high doesn`t but the 4x4 low does, I figured something happend to the led for the 4x4 high so I took out the gauge cluster and did a test on the led and it lights up with no problem, I figured it must be the 4x4 cm because my 4x4 doesn`t work, it still has the orginal 4x4cm in it, I figured if the module was bad then the 4x4 low wouldn`t come on either, and opinions, I`m just going to order the 4x4 cm and see if that fixes the problem.
