InNeed
- February 4, 2001
- Lexington, Kentucky
- 1993 XL 5 speed 4x4
A few months ago my transfer case motor locked up on me while I was in 4x4 low. I couldn't get it back into 4x4 high or 2x4. I took it into a local shop and they checked all of the electronics and then removed the transfer case motor and found that it was very dirty and after cleaning it everything worked perfectly. The other day I tried to put my X into 4x4 low. Instead of shifting into 4x4 low it kicked me out of 4x4 all together. Would you think this is the transfercase motor again or electric? If it is the transfer case motor, is it worth cleaning again or should I just replace it? Does anyone know the typical price of a motor? I am worried this is going to be an ongoing problem and I am debating converting to a manual shifting transfer case. I would appreciate some info on prices (parts only not labor) and models of manual shifting transfercases and some of the pros and cons of making this conversion both in labor and performance.
Thanks
Matt
Thanks
Matt
