Mud4Life
- June 3, 2009
- St. Albert, Alberta
- '92 XLT
So I got a 92 XLT.
My new problem is 4x4's not working. At all. When I press the buttons on the dash I hear no noise, and no lights come on. First I went to the shift module and made sure it was working.
Did the test and the LED flashed four times. Next I crawled under the vehicle and tried to rotate the front axle shafts... I can't turn them at all... I don't know if this is normal, but a lot of write-ups said to turn them forward until the hubs engage. I started to think I was already in 4x4.
I pressed the 4x4 button one last time even though nothing happened and I backed down the driveway. When I stopped I heard a bit of a clunk from the front end. I didn't wanna crawl underneath the truck on a slanted driveway so I drove into the garage and there was still no change.
Now I have a few questions about what to do next. The ONLY thing I know that works is the shift module. What is the easiest way to check that the buttons on the dash are even working? After this I will take off the shift motor and clean that out.
Now my last question is...Say everything is working except the shift motor. When I press the button should I still hear a clicking or w/e sound from the shift module? Or will the shift motor send a signal back to the module and shut everything off before it even makes a sound?
Thanks. Matt
Thanks. Matt
