msphynx
- October 30, 2005
- Atlanta, GA
- 93 Ex 4wd Eddie Bauer
I've looked through the forum and have found countless entries on the shift motor, I've checked most of it out and I've done some troubleshooting. Can someone review this and tell me what you think is wrong?
93 ford Explorer (Automatic) with 4wd Eddie Bauer Edition.
Issue:
4wd and low gear lights don't work when the button is pressed. Nothing happens no click or anything that I can hear.
Steps to resolve:
I removed the 2 connectors at the rear and pressed the button. I got several flashes then it went off. My understanding is this tells me the module is good.
Next I removed the Shift motor and manually changed the transfer box itself between 2wd, 4h and 4l. They all went in correctly with a springlick click.
Next I took the motor apart. It looked good but I did go ahead and sand down the armatur connection, the brushes and reseated them. I then had the wife start the car, place it in neutral and try the buttons while I held the motor and checked it out. When she pressed the 4wd button the motor never fully left the 2wd position. It just jerked back and forth slightly a few times as if it was hitting it's limits or something. At this point I took the motor apart again and manually manipulated it to it's farthest setting the 4high. Put it back together and held it while she repeated the test.
When she started the car she told me the 4high light was now on. (yippie! I figured the wiring was good at this point!)
I then had her hit the 4 low and the motor properly moved to the correct position. I had her go back to 4 high and again it went properly. Then I had her return it to 2wd and it went there perfectly. At this point I was excited that it was probably fixed and not a wiring issue. So...I on a hunch had her to try the 4wd high again and again it exhibited the jerky motion and didnt leave the 2wd position. She then tried 4 low and again same jerky results still in 2wd positon.
So at this point I'm thinking...everything is perfect in the system (wires, etc) except...the shift motor gearbox thing behind the darn security screws. I've yet to take it apart as I don't have the #20 torx for security to remove it.
Any idea where I can get this? And...am I on the correct track? It's probably something in there like the stop limit piece might be broken or something? Or could this still be a wiring issue?
To fully remove the motor so I can work on it what do I need to do. I can fully remove the motor from the case and then the connector with like 10 wires in it I got it apart. My issue Is the 2 wires running into this rubber piece that plugs into the case itself and then the single wire about an inch to the top right of it. Do I just PULL real hard to get these out or what? I don't want to break them getting them out.
Thanks for your help.
Issue:
Steps to resolve:
