navynmr
- December 19, 2007
- Amherst, NY
- 2001 Ford Explorer Sport
I have a 2001 explorer sport. I have a problem where it engages into 4wd hi and low fine. When i switch back to 2wd the light shows its changed, but i still can feel it in 4wd, after driving a lil, randomly it goes to 2wd. All the lights work fine.
I removed the shiftmotor opened it, the brushing was fine. cleaned dust off the motor brush contacts. Put everything back, and same thing.
I saw something that might be the prob but am not sure.
The motor casing in between the two magnets at the end has a seating for the metal rod that goes in, and it moves pull the motor to one side of the magnet. Is it supposed to? or should it float in the middle? Could that cause the motor to get stuck?
Do you think i should replace the shift motor with a new one. Or do you think its something else. Thank you soo much
