Fr0z3N
- January 12, 2008
- Mississauga, Ontario
- 99 Sport
99 sport 4x4 5spd
I followed this
Got to step 3, with the front in the air, car idling and 4x4 High on, I can still spin the front wheels.
It's been like this since january. It use to click or hop when turning but that eventually dissapeared
I followed this
97-01 4-door and 96-00 Sports
Your control knob should say 4auto, 4high, 4low.
First, we need to narrow it down to a transfer case issue, or a front axle issue.
Step 1) Jack up the front end and place it securely on jack stands.
Step 2) Verify that the front driveshaft turns by hand. When turning the front driveshaft by hand, the front wheels should turn. (If only one turns, don't be alarmed. One wheel sometimes has more resistance in the brakes, bearings, or CV joints. This is normal)
Step 3) Start the vehicle and let it idle in PARK. Engage 4high. DO NOT PUT THE VEHICLE IN GEAR!!! Crawl underneath and see if you can turn the front driveshaft.
**If you can turn the front driveshaft, the transfer case is not locking. This could be due to a mechanical issue with the transfer case itself, or an electrical gremlin with the control system. Start a new thread with the results of your checks, and we'll go from there.
**If the front driveshaft does not turn, the transfer case is locking properly and we need to continue searching.
Step 4) With the front wheels in the air, engine idling in PARK, spin one front wheel. The other wheel should spin the opposite direction. If both wheels spin in opposite directions, then the front axle *should* be properly engaged. Take it for a test drive (after safely lowering it to the ground, of course). If the front wheels do not spin in opposite directions, there is a problem with the front axle. Start a new thread with the results of your checks, and we'll go from there.
