5.0 CAM Help
Accarguy
Chicago, IL
2000 Explorer 5.0 AWD
I am going to upgrade the cam in my 5.0 and I have narrowed it down to 2. I want to know if anyone has any opinions on either. This is my daily driver. Both are from Comp. I am leaning toward the second one.
SPECS:
XE266HR
35-514-8
RPM 1600-5600 Lobe Sep 112 Center line 108
Duration
Int EX
266 274
Lift
544 555
XE270HR
35-310-8
RPM 1500-5500 Lobe Sep 112 Center line 110
Duration
Int EX
270 276
Lift
533 544
Obviously the second is a bit more aggressive, but how aggressive is the million dollar question.
Thanks for the input
Join the Elite Explorers for $20 per year. Gets rid of the ads! New $5 per month option.
VR4
vancouver, wa
01 explorer
Both are far too aggressive without tuning. If you can tune it you'll still probably want a stall to help get this pig moving.
I've got the 258hr 35-510-8 grind and it's great. Very rarely it does stall on hot restart and immediately dropping into gear but it I wait a few seconds it's fine. No misfire codes either.
Accarguy
Chicago, IL
What do you mean by stall?
The 35-510-8 looks like the more popular one to go with and says it is a great factory replacement. And it says the 35-514-8 has a slight idle though.
How is the idle/ roughness of yours. Do you by chance have a video of it?
thanks for the input
VR4
vancouver, wa
01 explorer
Sorry. In the first instance I was talking about a torque converter with a higher stall speed. Allows the engine to rev higher before effectively transferring torque.
Second mention I mean the engine dies.
In my case it's only slightly rougher than stock. No lope. Wish it had just a little.
Before cam.
https://youtu.be/EfSBMVLbqt8
After cam.
https://youtu.be/RbrG6fCy80A
Accarguy
Chicago, IL
Your fine. So you would recommend getting a torque converter then? Do you have one?
What did you do for a tune in yours?
VR4
vancouver, wa
01 explorer
My cam has about the same duration as stock but a ton more lift. It drives like stock until you get on it. No need for a higher stall converter.
I haven't tuned it yet. Still looking into options
shucker1
Metairie, Louisiana
98 XLT 5.0
I have the standard 266HR in mine (35-308-8).
Mild rumble and plenty of bottom end guts.
Dyno Tune did wonders.
I am pulling a 5500# boat so it helps get out off the ramp.
SWIGIN
PA
79 Bronco , 98 Explorer
I have the Comp XE276HR in my Stang and it is a very wild cam. Very lopy idle that sounds beautiful but I would not go near that big in my EX. My Mustang needed a high stall converter ( 9.5'' 3000 stall) to work correctly with that cam.
Comp makes an Extreme 4x4 cam series for some engines but not for the 5.0 that I have seen. I have an Extreme 4x4 cam in my built 460 and it is perfect for a 4x4 or suv. It has explosive power right off idle and pulls hard to about 5500 rpm with a nice lopy idle.
If they made the Extreme 4x4 for the 5.0 I'd go for that in a heart beat.
I know this don't directly answer your question but the first two you posted are close to my Stang cam.
VR4
vancouver, wa
01 explorer
Keep in mind if you need to go thru emissions and can't get a tune having a lopey cam will throw a p0300.
My s10 has a 276hr iirc. Nice lope especially for a v6 but does have a random misfire stored. Ford computers are more sensitive than GM in picking up and pinpointing misfires too.
Accarguy
Chicago, IL
Thanks for all the input
[MENTION=290160]VR4[/MENTION] I just saw your youtube videos and you are right there is not much of a difference at idle between the two.
If i went with the 270 it would not be as aggressive than your 276 and I am probably going to get it dyno tuned after I am all done.
Accarguy
Chicago, IL
Please share if you have a cam in your 5.0 Thanks!
fastpakr
Roanoke, VA
99 4wd - 5.0/4R70W/BW4406
In case someone is considering Trick Flow's 'Track Max' stage 2 cam, I wouldn't recommend it. Way too much duration for a semi-stock engine in a heavy truck. Maybe if I'd had a matching torque converter and more compression. No power through almost 3000RPM, then pulling like a freight train when the 4R70W shifts at just below 5000. It would also help to get a tune to adjust the shift points.
The things you learn when you get the wrong cam in the box...
MrQ New Cam Help 5.0 Modified 1995-2001 Explorers 12
R Need help with cam selection! Modified 1995-2001 Explorers 8
9 Help me out with a cam swap in a 5.0L V8. Modified 1995-2001 Explorers 14
M 5.0 bigger cam, no tune? Modified 1995-2001 Explorers 28
D 1996 explorer cam swap on stock ecu Modified 1995-2001 Explorers 9
W 5.0 Explorer cam options Modified 1995-2001 Explorers 16
6 1999 explorer cam improvement. What needs to be changed? parts wise Modified 1995-2001 Explorers 6
D '00 5.0 cam position sensor voltage questions (p0340) Modified 1995-2001 Explorers 45
S Cam change& injectors? Modified 1995-2001 Explorers 0
1 Some headers And maybe cam for 97 mountaineer Modified 1995-2001 Explorers 24
J Rebuilding 5.0 v8, best parts to buy? cam? Modified 1995-2001 Explorers 7
T Big Cam Modified 1995-2001 Explorers 3
96ex5.0 1.7 roller rockers or cam swap Modified 1995-2001 Explorers 15
R Is this cam too big? Modified 1995-2001 Explorers 9
K 5.0 upgrading cam recommendations Modified 1995-2001 Explorers 11
R Cam pos sens. Wiring conversion PROBLEM! 3 wire to 2 wire! Modified 1995-2001 Explorers 1
V XE258 Comp Cam Modified 1995-2001 Explorers 53
96ex5.0 F303 cam swap Modified 1995-2001 Explorers 2
A 422 Cam in a Stocker Modified 1995-2001 Explorers 1
W Cam Sensor Modified 1995-2001 Explorers 2
1 COMP Cam gains fuel mileage? Modified 1995-2001 Explorers 0
N 422 Cam for 99 Modified 1995-2001 Explorers 0
M 5.0 Mustang cam swap ? Modified 1995-2001 Explorers 3
W dual valves springs OK with stock cam? Modified 1995-2001 Explorers 35
T p0171 and p0174 after cam sync replacement Modified 1995-2001 Explorers 0
T 5.0 Cam Modified 1995-2001 Explorers 0
E 5.0 cam suggestions Modified 1995-2001 Explorers 7
M Cam synchronizer replacement? Modified 1995-2001 Explorers 0
T My cam sensor swap Modified 1995-2001 Explorers 1
F cam and gears Modified 1995-2001 Explorers 0
T 5.0 Cam selection Modified 1995-2001 Explorers 27
S yet another cam question... Modified 1995-2001 Explorers 0
T delta cam rocker arms trashed Modified 1995-2001 Explorers 122
D Gear drive for Cam Shaft??? Modified 1995-2001 Explorers 2
L 97 Sport, swapped in aluminum head 5.0 with small cam Modified 1995-2001 Explorers 11
T Will I lose low end torque by using an B303 cam with a mild 306? Modified 1995-2001 Explorers 82
P 410 cam install - retune required? Modified 1995-2001 Explorers 2
J Which cam? Modified 1995-2001 Explorers 39
D Where to get a good cam fr 5.0 engine? Modified 1995-2001 Explorers 12
K List for cam chain replacement Modified 1995-2001 Explorers 0
J 99, 4.0 ohv cam swap Modified 1995-2001 Explorers 3
T b cam Modified 1995-2001 Explorers 9
9 cam for (99)5.0 ex Modified 1995-2001 Explorers 22
D Cam question 5.0l 302 cid Modified 1995-2001 Explorers 15
Z cam swap in a 99 explorer Modified 1995-2001 Explorers 3
A time for a cam Modified 1995-2001 Explorers 0
0 Good cam for 4.0 sohc? Modified 1995-2001 Explorers 2
V COMP Cam Advice Modified 1995-2001 Explorers 3
C comp cam install??? Modified 1995-2001 Explorers 0
local7teener 911 - Wrong cam position sensor??? Modified 1995-2001 Explorers 8
Similar threads
