alright, i am starting to come to conclusions about my engine buildup and would like some feedback and questions answered.
i have 93k on an AWD 97 Mounty (internal EGR&non-P heads), so engine is staying in. here is what i plan to do:
x-305 heads (58cc chambers will give me 9.5:1 or so compression)
1.6 RR's
aftermarket cam undetermined, but mild with a decent idle and good torque
torque monster headers
undetermined cat back setup (just need to find the one that sounds right)
cold air kit with a ~76mm aftermarket MAF
24lb injectors
255in-tank fuel pump (because i have it in my garage)
chip/reflash
looking for around 340hp. possible?
ok, its time to help fill in the blanks. biggest thing is the cam. i have searched and nobody seems to have any better suggestion than the E-303. this cam sucks. it sucked on my 95 mustang and it will suck on an explorer engine. the 110 lobe separation does horrible things to the engine. granted, alot of people, both in the mustang arena and of the explorer variety, have had luck with this cam, but an equal amount of people of both venues have had bad experiences with them. so why would i even bother when i have the choice of what i can buy? besides, all ford letter cams completely ignore the flow characteristics of ford and aftermarket ford heads. exhaust flow is not good, so a split pattern cam is what they need. none of the ford cams offer this. so, i want a split pattern with a good low end torque curve, right around .500 lift with 1.6's and a lobe separation guaranteed not to mess with my computer. and not a custom grind. gotta be under $300.
next is the chip. whatchall using? is there a good all around canned tune? i have dealt with 3 tuners on my mustang and they are all ***** and screwed up while charging me a buttload for either a new chip they can work with or charging me for dyno and burn time because i didn't get the chip from them. **** them. (can you tell i am a bit bitter about the situation?) i want to plug in and go...or something like a PMS, where i can adjust parameters myself.
lastly, will i need to replace my cat/midpipe setup? i have yet to see any aftermarket high flow cat setup. anyone got a lead on these?
any other comments or suggestions are welcome. thanks!
1.6 RR's
24lb injectors
chip/reflash
