5.0 throttle body?
james t
Moderator Emeritus
Texarkana AR/TX
94 SAS sport
ok. i did a search on this and found a bunch of the same questions, but no definate answers. as far as i know, no one makes an aftermarket (bigger) throttle body for the 5.0 X. so, what would be involved in adapting one from the 5.0 stang aftermarket? is it easier to use one for a 86-93, or a 94-95? i know the stocker is 65 or 66 or whatever and they will support 300+hp, but later when im done that wont be enough.
blk mk8
brother
Troll's
the stock one will be good for a while but if you want you can take a 93 or older one and adapt it to work you need to take the shaft and linkage off to make it work with the old parts. there are other ways to do it but that one will be probibly the most easy way.
