njmalibu313
- February 2, 2009
- NJ
- 97 5.0 4wd
Hi guys,
After figuring out that my water pump water pump was trashed (pully shaft bearings), I decided to replace the pump, thermostat, and serpentine belt.
Everything was going well, until I broke a stud, but still protruding at least 1-2 inches out of the timing chain cover. Well, rather than try and fix it, and fear making matters worse, I went ahead and installed it anyway,hoping the other 8 bolts and studs would prevent any leaking.
After getting everything back together, and a test drive, I am getting leakage. However, its very hard to tell exactly where the leak is coming from.
My question is, what is the likely hood of the leak being from the location of the broken stud? Does anyone think that any missing bolt will cause a leak?
I guess I need a confirmation here to actually admit that I f'd up, and will likely need to tear it back down, and extract the stud, so my next question is;
has anyone had a similar problem like this, and what was your solution? Since I have 1-2", I was planning on welding a socket or nut onto the stud, and trying to get it that way. Anyone have any other tips or suggestions here?
Thanks
Thanks
