visor mirror
- August 29, 2008
- Beacon Falls, CT
- 1991 XLT 5 spd
I have a 1991 Explorer 5 speed with 210,000 miles. I installed a new engine at 158,000 and put in a new clutch, and slave cylinder with the integrated bearing. Currently having trouble shifting, as you slow down it is necessary to be down shifting and get into first gear before stopping or it isn’t going into first or any other gear.
The trans stays in every gear once you get there. I have read that if the slave cylinder and bearing are worn the difficult shifting is a symptom, but it has only been 52,000 miles ago.
I not familiar enough with this transmission and I am not sure if it is a slave cylinder condition or a transmission problem.
Your thoughts are appreciated.
