5 speed swap questions | Ford Explorer - Ford Ranger Forums - Serious Explorations
Supercracker
Nor cal
96 exploder
So i recemtly picked up yet another explorer (95) solely for the motor, knowing it had a bad trans (automatic). Loaded it up without any questions amd headed on my way. Turned out to be a 2wd. So my interest is now peaked at the endless possibilities of swaps. But my question is what 5 speed could i use with the 4.0? Ive been told by a buddy that the 5.0 is a bolt in swap with the 4.0 auto trans. Is this still true with the 5 speed? He also says the m50d from the f150 with the 300 6 cylinder is the same. Its going to be a project regardless what i do with it. But would like to 5 speed swap first then maybe dowm the line 5.0 swap it with out doing trans again as well
fastpakr
Roanoke, VA
99 4wd - 5.0/4R70W/BW4406
The 4.0 has a different bolt pattern from the 4.9/5.0. If it's a 4.0 engine, you'd need a 2.9 or 4.0 5 speed from a Ranger, or a 4.0 transmission from an Explorer.
Supercracker
Nor cal
96 exploder
So the transmission from 4.0 wont work with a 5.0?
fastpakr
Roanoke, VA
No, definitely not..
Supercracker
Nor cal
96 exploder
Ok thanks! My ford buddy has been feeding me false info for a while it seems lol
SupaSwope
Florida
99 Mountaineer 5.0 RWD
You need a M5R1 or M5R2 also know as M5OD-1 or 2
Supercracker
Nor cal
96 exploder
For which motor? From what im understanding the bellhousings are different?
fastpakr
Roanoke, VA
M5ODR1 or M5ODHD are Ranger /Explorer 5 speed transmissions and you'd need one from a 2.9 or 4.0 to bolt up to a 4.0. For a 5.0,you'd need an M5ODR2. If memory serves, you'd need one from a 4.2, but I don't remember why that engine version is required. 4.9,5.0, and 351W/351C all used the same bolt pattern.
SupaSwope
Florida
it does have to be from a F150 4.2 between 97-03 i believe. or can one from a F150 with a 302 in it. but the revision of the transmission does not matter if its m5r1 or 2. The 2 being a more beefy unit from what I have read.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
The m5r1 is for v6s, the m5r2 is for v8s.
fastpakr
Roanoke, VA
R1 was also used behind the 2.3 liter 4 cylinder, for what it's worth. Essentially the R1 is a smaller transmission though. Not a generational thing at all, they're just built for different applications.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Sure, and probably the 3.0 too, but the bolt pattern is different for both of them and not swappable to a 4.0.
fastpakr
Roanoke, VA
That's correct, I was just responding to the 'M5ODR1 for V6's' bit.
Mbrooks420
High Voltage.
1998 Mountaineer AWD
Even if the 4.0 transmission bolted up you’d be crazy to do it. The M5OD’s aren’t the beefiest transmissions available, but they are a step up from the 4R/5R.
roscoe 0202
salt lake city utah
1999 explorer sport
unless you're speed shifting the m50r1 is a good trans behind a 4.0.
roscoe
