ozydeco
- December 28, 2007
- NC
- 94 XLT, 94 Sport
'97 Explorer 2WD
130K mi
Symptoms: 'typical 5R55E gasket symptoms' as I research this forum: dropping OD, then no 3rd, intermittent shifting of all gears for a few days my Daughter reports, but 'when it catches - it works fine'
Expectation: I was hoping to find a crack/hole in the VB gaskets, and replace them.
So I pulled the trans pan and the mounting bolts for the Valve Body have all lost torque, finger tight, but no evidence of a torn gasket. Worse, there is no Reverse Servo Cover Gasket - meaning, that along with some fishy looking bolts in the Cat-Conv. exhaust manifold flange lead me to believe someone else has been in this transmission. Fluid in the pan is darkish, no shards or chunks of any kind, no burnt smell, fluid dripping from the valve body is red.
What to do ? Typical '97, nice outside but my Daughter has 2 large dogs, interior/seats are a mess, but the engine runs ok, typical clanking timing chains etc. but starts and runs reliably still. This truck running properly would bring a whopping $1000 on a good day - I'd like to get her another 5k miles if possible - read, a little time for her to save more money for a new vehicle.
I'm not sure where to draw the l$$$ line, or even what's my best options are ?
I've rebuilt engines/appliances/computers etc. for decades, but my experience with transmissions is strictly 'book learning'. I usually do things right, but how much cost is worth investing here - and what parts are worth trying ? I've seen rebuild kits for $400...wow...
I was thinking the VB gaskets may be leaking and worth a try for $20, meaning add 8 qts of fluid ($40) = $60 I can't see buying an EPC for $100, probably look into the test procedure first though, and if it tests bad - I'll buy one.
Can the pan gasket be reused ?
Kerosene the filter ?
How much would you spend on transmission parts for this vehicle, with this goal of just getting another 5k miles....in any forward gear ?
Any advice/wisdom for me on this issue ? Feel free to tell me I'm an ignorant hammerhead for not pulling it and trying the full rebuild, I'm considering it as a personal challenge. Based on what I've read, one needs a few high dollar tools to do this right, drill/replace bushing - etc.
Also, if anyone has an experience with a junkyard tranny - Please share...
Thanks,
David
130K mi
Thanks,
David
