BeefMan
- August 26, 2014
- Colorado Springs, CO
- 2005 Explorer Sport Trac
5r55e from a 2005 Sport Trac 4x4. Failed at 163k miles.
First, some background on the tranny. Several possibilities as to why it's failed - I haven't opened it up yet so can't be 100% sure. I'm literally doing that as I'm posting this thread. I noticed a weep between it and the transfer case, and I believe gasket failure, loss of fluid, and subsequent overheating to be the original cause. Was pushing the truck really hard on a really hot day. And blam, fountain of ATF, no reverse, nothing beyond 2nd. Full extent of damage is yet to be seen.
Second, I've never done anything like this before. I actually didn't even know how the tranny worked until I started researching a few weeks ago. Anyway I figure others have done it at home, and if I can do it, anyone can. Plus I like seeing a lot of pictures, specifically on this forum, before I jump into something, so I'll be putting a bunch of pics up.
Oh right, this is the disassembly. I'm skipping removal for now, will also be doing the reassembly and install stuff, possibly in another thread - will need to order parts first. Anyway, let's go!
Our victim... err... patient. First I hauled it out to clean it off. It was caked in a mix of dirt and ATF that got cooked onto the case. I did my best to not allow water into the case, but this thing is dead anyway, so I wasn't too concerned. With all things in this thread, if you're going to try this, use your best judgement.
Now this is the first major problem. The main case is cracked near where it meets the extension housing. I did not notice this till I got it out from under the truck. I used a tranny jack, but I was a little rough with it, so it may have been careless removal or perhaps a hairline fracture there was the original leak. The truck is too low to the ground on the stands, so I had to pull it off the jack and drag it out. Anyway, have a new case sitting in the garage. $85 off ebay.
Get her on the bench, and pull the torque converter straight out. It will be full of fluid and heavy. Then pull the input shaft straight out (pictured on bench).
Next, pull the Overdrive Drum Sensor, Output Shaft Speed Sensor, and the Manual Control Arm. You MUST hold the arm while you take off the nut, or you WILL brake a tiny arm inside the case. The sensor locations are pictured, only one bolt holds each, then they just pull out. They are very similar in appearance, but will only go in their specific hole, so come install time don't worry too much.
More to come. Like I said, I'm doing this right now. I will try to keep things in order and take good pics. Sorry if I discuss things too much and make the posts huge, but maybe it will be helpful to someone. I dunno haha. If anyone wants to actually try this down the road, definitely get the ATSG or actual Ford Shop manual (or both). I have the ATSG.
